Will it fit?
Old Apr 22, 2008 | 10:42 PM
HURRICANE_ZC's Avatar
Will it fit?
I have an idea of a killer system buy im not sure if it would fit. I want to put 4 8in DDs under the rear seat and mount my amps behind the seats. I know i will custom fit a box but wasn't sure if everything would be alright like air space and everything. Anyone have any thoughts.
Old Apr 23, 2008 | 12:07 AM
marcolarco52's Avatar
dont know if there will be enough airspace to fit 4 8's...pretty sure that wouldn't be enough
Old Apr 23, 2008 | 02:21 AM
Low_e_Red's Avatar
Enter Styx...
Old Apr 23, 2008 | 02:24 AM
mSaLL150's Avatar
Originally Posted by Low_e_Red
Enter Styx...
x2
there is plenty. depends on the driver, but it can easily work.
Old Apr 23, 2008 | 10:39 AM
Hallertau2000's Avatar
DD 8"s you'll only get 2@ 1.5cu ported under your seat sadly enough but they'll be as loud as any other 4.I've seen 145 from 2 DD 8's but they don't sound all that great.
Look up Soundsplinter Rli 8" these might be what your looking for.Although I have'nt the pleasure of listening to them. Reviews of these are saying they get almost as loud as DD and sound Great while doing it, they use a much smaller box.5cu ported so 4 would fit.If money was no object I would buy these.
I went the cheap rought and bought 4 boston g108 sealed they pound but are a little lacking in the SQ department but O.k. for a 50 dollar each speaker. I wish I would have spent a little extra cash on 4 Arc 8" or Image Dynamics ID 8"or JL8w3v3 all of these sound great with some better lower end extension than the Boston at about twice the price 99 dollars per speaker.
James
Old Apr 23, 2008 | 11:04 AM
styxnpicks's Avatar
the dd 1508's are too deep @ 5.25 mounting depth. the Rl-i8 8's are even worse at 5.65. I BARELY had room to mount eD 9Kv.2's which are 4.375 mounting depth, you cant fit much more than that... maybe about 4.5 MAX if the pole isnt vented
theres also only about 1.4-1.5ish cu ft under the seat.. BARELY enuff to run 4 sealed depending on the driver.. which isn't a bad thing but the massive 8's like the 1508 and Rl-i8 really need to be in a ported box....
Old Apr 23, 2008 | 11:45 AM
Styx, with my LMI 2.5 lift the new sealed box I just made will fit any 4 of the woofers you just mentioned sealed and it's only under the longer bench side of the rear seat 33.5x6.5x5x19 1.37cu with a 2 inch foot on the front if I used the whole underneath the seat I could easily do it ported. Brypink put 2 10w7's under so there's more than 1.4cu under the whole seat.
There's 1.6 under the longer bench side seat that's about all maybe a little more but you'll have to use the drivers side rear underseat well a little. I'm really contemplating trying a 13w3 downfiring sealed.
James
Old Apr 23, 2008 | 11:51 AM
styxnpicks's Avatar
were talking no $$$$ seat lift here
Old Apr 23, 2008 | 12:21 PM
what about the kicker L7 series 8 inch subwoofers they have like a 4.75" mounting depth...the sealed space it says recommended is .33-.75cu/ft
Old Apr 23, 2008 | 12:46 PM
styxnpicks's Avatar
4.75 might be too much. specially if there is a pole vent
Old Apr 23, 2008 | 12:55 PM
Doh,
I just figured if he was talking about DD then a seat lift was part of the equasion,My Bad.
Styx, your right the best woofer without lift is probably the ED 8".
Altough,I've been told the ID 8 and Arc 8 can have the magnet cover/shroud removed for pretty small mounting depth.
James
Old Apr 23, 2008 | 01:02 PM
styxnpicks's Avatar
Originally Posted by Hallertau2000
Doh,
James
the arc 8 is VERY similar to the eD 9kv.2.... the baskets are identical and the motor is probably the same, only diference might be the soft parts. looking at the specs I could drop them in my box no problem, altho I don't know if they can take 300rms
Old Jun 21, 2008 | 09:32 PM
Black Truck 10's Avatar
so what ever came out of this, what did you finally choose?
