New JL 13.5
I AM SO EXCITED ABOUT THESE I WILL BUY 2 OF THEM IN JUNE AND THEY WILL FIT UNDER THE SEAT WITH OUT A SEAT LIFT. THEY SHOULD SOUND GREAT! IS ANYONE ELSE STOKED?
13TW5-3
Nominal Diameter: 13.5 in. (345 mm)
Continuous Power Handling: 600 W
One-Way Linear Excursion (Xmax): 0.36 in. (9.1 mm)
Voice Coil Diameter: 7.00 in. (178 mm)
Nominal Impedance: Single 3 ohm
Mounting Depth: 2.50 in. (63.5 mm)
Recommended Sealed Enclosure: 0.75 cu.ft. (21.3 liters)
13TW5-3
Originally Posted by marcolarco52
pretty expensive.......the box will stick out quite a dam bit cuz its a 13.5" sub lol....my box sticks out a little and i got 10's
NO IT HAS ONLY 2.5" DEPTH YOU CAN BUILD A BOX THAT WILL NOT STICK OUT AT ALL ONLY .75 PER SUB
Originally Posted by CHUCKO1404
GOOD SQ AND BAD $ 550.00 MSRP
or get other low profile subs which are far far less...
when you can use fullsize subs anyhow
STICK OUT?
The speaker is still like 13" in diameter, so the box has to be at least that deep, plus the thickness of the MDF (plus maybe some buffer zone of air?). Dunno about you, but I think that would probably stick out a little for me, too.
Hmm....those are cute.
2.5 inches of mounting depth is damn cool though, not gonna lie there. However, the 13.5 inches....plus another 1.5 for wood thickness MINIMUM is a 15 inch deep box as someone else said. Might take up a little extra feet space down on the floor.
Originally Posted by wookie13
OMG!!! $550.00 FOR A SUB
I could have a box made WITH subs for that much!!!
Originally Posted by cbarronx23
I ate a sub for dinner. Only $4.95 and it came with lettuce, tomato, turkey, swiss cheese, and a bag of chips.
Must not have been Subway
Frikin 8 bucks for a sammich, bag of chips and a pop...screw you Subway, screw you :fistraisedinair:
Originally Posted by styxnpicks
subway and JLs subs are overpriced... if you have to pay for a sub get quiznos or penn station
