Speakers on outside of truck
Old Feb 11, 2008 | 01:30 PM
steelshot220's Avatar
hey folks,
i have ALOT of bonfires and campouts ect. and always end up backing into the camp and opening my doors for some tunes.
well i thought of a bettr way... could i get two 6x8 marin speakers and mount them in small conter enclosers under my toolbox in the bed?
the only thing is i want to be able to switch them on and off. so cound i just just splice them to the exsisting back speakers with a switch in the middle?
Can someone tell me if this is possible?
i hope so cause that will be sweet as hell
thanks
Old Feb 11, 2008 | 02:09 PM
i can just splice into the back speaker wires correct?
and will a 10 amp rocker switch work?
Old Feb 11, 2008 | 05:17 PM
Low_e_Red's Avatar
Technically yes, it will but there are better ways of wiring that up.
And why 6x8's not 7's or 6's (which will be WAYY MORE prevelant).
Old Feb 12, 2008 | 03:22 PM
What would you suggest as a way to wire them up???(dont wanna buy an aditional amp)
i guess i thought that 6x8 were the loudest? and i cant find enclosers for anything other than the 6x8s... feel free to change my mind
Old Feb 12, 2008 | 04:13 PM
Crewwzin's Avatar
I believe you mean 6x9's. Those are more readily available and will get a little louder.
Old Feb 12, 2008 | 04:29 PM
ModBargains's Avatar
Click the picture for a link
Old Feb 12, 2008 | 04:31 PM
Mr. eXtreme's Avatar
Exclamation
Why not build you own enclosure....
And throw a set of 7" Marine speakers in there!!
Taking note that outside of the truck you have rain etc...
Or being that you hold Tailgate parties. Your buddies Beer etc...
Old Feb 12, 2008 | 04:32 PM
Thumbs up NOW these are cool 2
Seen these used on Bikes and Quads before....
Have a truck box... Mount em under that!!
Old Feb 12, 2008 | 07:35 PM
Low_e_Red's Avatar
Do all wiring behind radio, Take a switch and wire up to Ignition, then take 2 relays:
86 - ign behind switch
85 - Ground
30 - From deck RL or RR (depending on corresponding side)
87 - To Marine Spks in bed (you will need to run wires all the way back to the bed
87a - To factory spks via wires behind deck.
[numbers are corresponding to relay terminals, Will be on SPDT 30/40A Bosch relays (those are standard auto relays)]
Therefore, when you flip the switch, you will change from the rear spks to the bed spks. When turned off you will then have the rear spks on.
It sounds real complicated but will take all of 15-30 min to wire up.
Old Feb 12, 2008 | 09:13 PM
85 - Ground
god... i wish i could just get you to do it
Old Feb 12, 2008 | 09:41 PM
Screw-Me-05's Avatar
Holy christmas trees...... now i've seen it all what will they think of next?
Old Feb 13, 2008 | 12:37 AM
Low_e_Red's Avatar
Actually, that may be possible with the exception of running the wires to the bed. Id just pick up all the necessary parts and wire it up. And with a little shipping it be at your door. (Two day shipping for Ground... Memphis is Fedex Central location for the area. And happens to be my Central Location)
Email me.
Old Feb 22, 2008 | 02:22 PM
davewvu86's Avatar
I go to tailgate parties, bonfires, etc a lot too. My solution was a set of 6x9's in boxes. I bought the boxes from wal-mart for like $20 and I have some cheap 6x9 pioneers from best buy.
I ran RCA outs for all channels back to my sub amp when I installed my amp. When I want to use the speakers I take an extra 2 channel amp I have laying around - 75x2 at 4ohms - and just quickly wire it up off of my sub amp...just run a short piece of wire from each - power, gnd, remote to the 2 channel. NOTE: I jump directly from my sub amp to the smaller amp to avoid having to buy power distribution blocks, etc. It's minimal drain and not a full time install. I have 2 ga. power and gnd running to the sub amp and use 8 ga. to split off to the 2 channel.
I then plug into the front channel RCAs. Takes maybe 2-3 min. Then i throw some long speaker wires out of the rear window and put the speakers in the bed or on the roof. Set up takes 5 min max.
I use mine all the time at massive tailgates at WVU, Skins games, etc.
If you have a 4 channel amp for your interior you could take the speaker wires for the front channels, run them to a switch and have the output split. position one on the switch would power interior front channels and position 2 would power the exterior speakers.
Old Feb 23, 2008 | 02:29 AM
Low_e_Red's Avatar
I wired everything up for him.
