Thunderform install...what did I do wrong?
Old Jan 22, 2008 | 06:02 PM
jskibi's Avatar
He said that the pin needs to be positive and the shield negative.
He said if i hooked the REM up, it would be on at all times and bypass the autosmart function.
Joe
Old Jan 22, 2008 | 09:42 PM
jskibi's Avatar
(deleted post)
Old Jan 22, 2008 | 09:45 PM
jskibi's Avatar
FIXED!!!!!!!!!!!!!!!!!
Removed the sub from the enclosure to find one wire disconnected. Reconnected and I was rockin'.
More sub than I expected. Not theater quality, but not muddy either.
Thanks to all that took the time to help me out!!!!!!!!!!!!!!
Hope I can return the favor some time.
Joe
Old Jan 22, 2008 | 09:49 PM
Low_e_Red's Avatar
Joe
Thats how it always is.... This rep is sounding smarter by the second....
On all the time... IDIOT REP. The woofer and amp are supposed to be on the entire time the radio is.
Play Moonbaby by Godsmack and you will understand why I say hook that up.
Old Jan 22, 2008 | 09:51 PM
Low_e_Red's Avatar
Joe
Glad it works.
Old Jan 22, 2008 | 10:59 PM
jskibi's Avatar
While we are at it...how does turning the bass up or down on the factory HU affect bass quality. Is it simply a gain, or does it affect frequency? What would be a good way to optimize the sub settings?
Joe
Old Jan 23, 2008 | 02:48 AM
Low_e_Red's Avatar
Joe
Leave everything leveled and adjust LP and Gains.
Old Jan 23, 2008 | 10:52 AM
jskibi's Avatar
Thanks as always!
Joe
Old Feb 14, 2008 | 02:27 AM
Koster88's Avatar
Thanks as always!
Joe
I was look at that 12 MTX Thunderform. Do you like it? if you could do it all over again would you do the same thing? What amp did you use? I will probably use an MTX 4002 I have laying around.
Old Feb 14, 2008 | 11:28 AM
jskibi's Avatar
Originally Posted by Koster88
I was look at that 12 MTX Thunderform. Do you like it?.
I do like it. Exceeded my expectations.
Yep, I would do the same thing all over again.
I purchased the powered sub. It came with a 200 watt amp. It punches well, hits all the low notes as well as fills mid nicely. I'm not a thumper but think this is pretty impressive for the money.
Joe
