help me with my set-up please...audio novice.
Is this set-up is okay...please give thoughts and opinions...
I am not looking for anything really really loud just something to give me a good thumpin'
(2) Rockford Fosgate 10" Punch (Model: P1S410)
4 ohm
Single Voice Coil
Mount Depth 5-1/5"
MAX 300W
RMS 150W
Rockford Fosgate 300 W Amplifier (Model: P300-1)
Class AB Mono
Dual 10" downfire Sub box mount under rear seat in 02 scab.
5.75" mount depth
.70 cu/ft per sub airspace
1. Will all that fit.
2. Where can i find it cheap? Or is there a cheaper set up?(i priced it out around $600 total.)
3. Is that enough airspace for those subs.
4. Should i use 4 gauge wire?
Thank you very much if anyone can help i will be grateful.
4 ohm
Single Voice Coil
Mount Depth 5-1/5"
MAX 300W
RMS 150W
Class AB Mono
5.75" mount depth
4 ohm
Single Voice Coil
Mount Depth 5-1/5"
MAX 300W
RMS 150W
Class AB Mono
5.75" mount depth
4 ohm
Single Voice Coil
Mount Depth 5-1/5"
MAX 300W
RMS 150W
Class AB Mono
5.75" mount depth
I have almost the same setup in my 07 Harley, except i have the p325.1 amp.
It's running off a LOC off the the stock NAV hu, sounds really good and pounds.
4 ohm
Single Voice Coil
Mount Depth 5-1/5"
MAX 300W
RMS 150W
Class AB Mono
5.75" mount depth
4 ohm
Single Voice Coil
Mount Depth 5-1/5"
MAX 300W
RMS 150W
Class AB Mono
5.75" mount depth
2. Anywhere.
3. It will work.
3a. Thats too much. Look elsewhere.
4. No. 8ga is fine.
The rms range on the p325 is 175 and the subs are only rated for 150...has that given u any problems...how much did u pay for your setup?
No problems yet, although i have yet to turn it up past 1/2 way.
Subs were $50cdn each boxing day sale, amp was $150cdn. oh and the box was a gift.
thanks for your help
