FYI cheap 5x7's
i had to mod mine a little bit to get them to fit. the tweeter stuck out too far and was hitting the gear that rolls down the window. i have manual windows and locks, so i just used some washers and spaced it out a little from the door so that it wouldnt hit. also the plug from my stockers did match the one on these. so i just chopped it off and soldered my wires on. a little bit of work, but i cant complain. they sound much better and were really cheap
Mine should be here today. Here are some instructions/pics I did for the '04+ Supercab speaker access and removal:
https://www.f150online.com/galleries....cfm?num=15487
Originally Posted by Copenhagen848
Just finished installing them....as mentioned simple plug and play - very easy to do.
I'm extremely satisfied with them, a big improvement over stock for under $20
Wonder how many they sold because of this thread? Thanks again, styxnpicks.
I ordered 4 of them and they arrived today. I just put in the two front one for now and they sound pretty good. More highs, which is what the old ones were lacking. I am think about NOT installing the rear ones and just leaving the originals in. It sounds good now. What to you guys think? If I put the two in the back will I loose all my bass?
These are good sounding speakers @ a great price. Thanks!!!
I think the new speakers handle the bass better than the stockers. I didnt change my rear ones either.
I had so much bass that, when cranked, my mirrors would vibrate badly. Bass you could feel. I lost some of that when I install the two ways in the front but gained highs. It is rumored that the 04 had better sounding radios than the 05+'s. Ford changed radio vendors in 2005.
Installed mine yesterday. It was simple. There is a slight improvement in sound quality. Have to turn it up a little louder to get the same volume it seems but for $30, I'm happy with the results. Now I can use the stock speakers in the garage with my old home receiver.
Thanks Styx!
Thanks Styx!
Thanks Styx!
Thanks Styx!
You'll need to run those in series if your home based reciever is set for 8 ohms and not 4 ohm capable. You'll have 2 speakers running off each channel for 2 total channels but still have stereo. No matter what its rated for, the reciever will probably handle the 4 ohm load until you crank it a bit. Then it'll probably go into failsafe.
Originally Posted by hllon4whls
Thats what I'm saving mine for as well. I have everything I need...except for the garage.
help with rear on SCrew
I ordered 4 and popped in the front two in like 5 minutes, then when i got to the back i realized that it wasn't as easy as the front. Does anyone know the trick to replace the back two w/o cracking my door panel? Thanks
Originally Posted by mSaLL150
without a sub?
