Box Build Up, Pics Inside!
Old Nov 28, 2007 | 03:13 AM
weazel's Avatar
Registered User
Hey people
I bought a box from supercrewsound.com, it was ok but the longer i had it the more i didn't like it. So i decided what the hell, i would try to construct my own. here is my progress so far. A member suggested middle supports, is it needed? Also i used Liquid nails and a nail gun to construct it. After the liquid nails dry im going to use silicone to seal it up tight.
Old Nov 28, 2007 | 03:14 AM
weazel's Avatar
Registered User
Continued...
Old Nov 28, 2007 | 03:20 AM
mSaLL150's Avatar
lookin good
Old Nov 28, 2007 | 03:38 AM
styxnpicks's Avatar
shoulda used titebond, liquid nails isn't that great for subboxes
Old Nov 28, 2007 | 04:47 AM
weazel's Avatar
Registered User
Never even heard of TITEBOND..
Old Nov 28, 2007 | 07:49 AM
kuruption's Avatar
I have used liquid nails (heavy duty) for several boxes with much success. I typically also use some quiet kote from parts express to seal up the enclosure.
I have also heard that gorilla glue works well.
Either way, if you can, you should go to a pep boys or similar and pick up what is known as "kitty hair"... it's basically a body filler mixed with fiberglass strands... it's great for sealing up sub boxes and is quite strong.
Old Nov 28, 2007 | 12:11 PM
CRF250rider1000's Avatar
I wouldn't use nails they don't really hold the box you need to put in screws every 4-6" IMO. Also don't forget to seal up all the joints inside with silicone and let it dry for 24 hours.
Looks good otherwise wrapping them is the biggest PITA I think
Old Nov 28, 2007 | 12:49 PM
hivoltagefx4's Avatar
Looking good so far! Can't wait to see the finished product.
Old Nov 28, 2007 | 01:22 PM
Bartak1's Avatar
Looking good.
I would suggest some type of brace in the middle too. Bracing is your friend when it comes to sub boxes
Old Nov 28, 2007 | 01:30 PM
mSaLL150's Avatar
That is what i was thinking, maybe a couple support pillars in the middle, since he wants to keep it as shared airspace and not divided.
Old Nov 28, 2007 | 02:19 PM
luke280's Avatar
Here is one of the better ideas for bracing a sub box and not isolating the subs from eachother. this guy is over in the fiberglass forums. Box is for a tundra, and the trashed seat is like that so the fiberglass top can fit in there.
Old Nov 28, 2007 | 05:33 PM
weazel's Avatar
Registered User
thanks for the input guys!
Old Nov 29, 2007 | 12:50 AM
azmidget91's Avatar
looks good bro
personally i like to separate the subs...well unless if they are running on the same amp(which i know you are) then it is ok to put them together but if one goes the other will follow soon after, and i would brace just the top the other pieces are small enough to where you dont need bracing
Old Nov 29, 2007 | 02:26 AM
DRJ's Avatar
DRJ
I like your tape! ... looking good though! let us see it when u b dun!
Old Nov 29, 2007 | 03:02 AM
GJ Screw's Avatar
You dont have any plans for that do ya? I am too lazy and thats the exact box i want!!
Jon
