would this be a decent setup
Old Oct 13, 2007 | 12:33 AM
king ranch's Avatar
i am planning on putting 4 12's in my truck audiobahns and for amp fun a hifonics crunch amp 3000 watts@1ohm (is that peak or rms what it will actually push, are these good amps or no) the subs are 700 rms a piece so will this setup have the right amount of power. and for powering everything will my batter and alternator be able to handle all of that, also are crossovers important to add in your system or no
the sub
http://www.millionbuy.com/adbaw1200q.html
the amp
http://www.millionbuy.com/crupzi30001.html
what do u think
thanks
Old Oct 13, 2007 | 02:31 AM
mSaLL150's Avatar
ill make a suggestion. ive owned/installed a lot of audiobahn subs and that specific model isnt a great one. i recommend their Alum Q line and their flame Q line. those are the best audiobahn has when looking for something that will play loud and sound decent at the same time.
the alum12n woofers have the exact same mounting depth and size as those ones you listed, and i guarantee you they will play louder and more clear. excellent efficiency as well. i have the 10" version in my truck currently.
http://www.woofersetc.com/index.cfm?...roduct_ID=2767
with that specific amp you could wire up 3 of the alum12n's and have a perfect 1000 RMS to each at 1ohm.
and you will definitely need to do electrical and alternator upgrades, and get at least one optima yellow top battery.
Old Oct 15, 2007 | 11:56 AM
GA FOO 88's Avatar
I wouldnt buy anything from either of those companies, ever. What kind of box, how big? Need more details...
Old Oct 15, 2007 | 11:59 AM
Devildog101's Avatar
Make sure you do your big 3. Do a search on it.
Old Oct 16, 2007 | 07:23 PM
king ranch's Avatar
well i wanting to do something like this behind my rear seats
https://www.f150online.com/galleries...668&anum=12527
i want at least 4 12's that are high powered and good amps but for this system i am looking to stay around $1000 i already have a new headunit, right now i have on 10" mtx i am trying to sell and a 1200 watt sony amp i am selling also might keep the amp for seleniums when i put them in my grill so i have very loud highs thats down the road
Old Oct 17, 2007 | 02:28 AM
Wookie99F150's Avatar
+1 for the Flame Q series. I had a single 10 in my Camaro that hit hard
Old Oct 17, 2007 | 02:34 AM
mSaLL150's Avatar
I used to have one ported (mine was actually the flame compression model, aw1008t). although it wasnt as clear in the ported box it sure put out a LOT of sound.
Old Oct 17, 2007 | 02:40 AM
GA FOO 88's Avatar
Considering that box doesn't look very big unless it extends into the bed somehow, I think you need measure out how big of a box you can fit back there.
*Make a cardboard mock up of a box like you would want.
* Then make a 1 cube cardboard box.
*Then fill the cardboard mock up with packing peas.
* Transfer the packing peas from the mock up box to the 1 cube box, to give a rough estimate of how much space you have
*remember mdf is 3/4 in thick on all sides, that will mean less space when you make an mdf box
Then maybe I can reccomend some better stuff.
