Do I need to amp my components?
Old Sep 30, 2007 | 09:51 PM
jdew1920's Avatar
I'd like to improve the stock system to something with more clarity and a little bit of low end thump but I am not into big boomy bass.
Recently replaced by head unit with a JVC double din unit (20W/ch RMS) - big difference in sound and a lot more features.
Based on recommendation from other forums I've got a pair of CDT CL61A (6.5", 120W RMS, 91 db sensitivity) components to install. If I install these without an amp could these sound good or should I expect them to be totally lacking?
If you think an amp should be installed with the components (which I think the answer will be yes) then do components supply a decent amount of bass or should I also plan on a sub? I was thinking of going with a 2 ch amp (100w/ch) and run the rears off of the head unit, but if a sub is a certainty then maybe I should go with a 4 channel and use the 2nd pair of channels to bridge for a sub in the future? Guess I could always install a 2nd amp if I needed to. If I installed a sub I think I'd be looking a something like a single 8" or 10" in a sealed box.
Oh yeah - where do you guys put your amps?
I'd appreciate any suggestions.
Old Sep 30, 2007 | 10:35 PM
alfack's Avatar
You know it, bro. You definitely need to amp those babies.
Since you said you are not looking for a lot of bass, I would try what you are planning. Get the 2 channel amp and see if it satisfies your thirst for bass. I have never heard the CDTs, so can't comment on how much bass they put out. But, if you set the crossover freq. on your amp low enough (~70hz), that might do it for you. If not, you can always add another amp and sub.
I have one amp under my drivers seat and one under the front middle seat/console. Others put them behind the back seat, but that is more work than I wanted to do.
Good luck and be sure to post if you have more questions. There are some knowledgeable people on this board.
Old Oct 1, 2007 | 11:47 AM
Devildog101's Avatar
Amp em'
Quickly!
