The sub thread to end all sub threads...
Old Sep 28, 2007 | 02:32 PM
luke280's Avatar
Ok not really, but it got your attention. lol
Since my mind and wallet are constantly changing, I figured I'd let the pros pick out my new subs. Looking for 2 10" or just one (need to keep the price around $200). Here's the amp that will be spanking the subs ****.
Rockford Fosgate Type RF X5
RMS Power at 4 Ohms 275 W x 1
RMS Power at 2 Ohms 550 W x 1
Here is the line of shallow subs that I have been looking at:
Kicker CompVT 07CVT102 Shallow 10"
10" 2-ohm subwoofer
injection-molded polypropylene woofer cone with ribbed Santoprene surround
suitable for marine use
power handling: 50-400 watts RMS (800 watts peak power)
frequency response: 25-350 Hz
sensitivity: 87.2 dB
top-mount depth: 4-5/16"
sealed box volume: 0.8-3.0 cubic feet
ported box volume: 1.25-1.75 cubic feet
Kenwood Excelon KFC-XW1000F Shallow 10"
10" 4-ohm shallow-mount subwoofer
carbon-glass fiber composite cone with butyl rubber surround
cast aluminum basket
power range: 50-250 watts RMS
peak power: 1,000 watts
frequency response: 35-800 Hz
sensitivity: 90 dB
mounting depth: 3-3/8"
sealed box volume: 0.6 cu. ft.
ported box volume: 0.6 cu. ft.
Pioneer TS-SW2541D Shallow 10"
10" 4-ohm shallow subwoofer
carbon and glass fiber reinforced IMPP cone with woven-fiber surround
Air Suspension Control System eliminates traditional spider structure
strontium magnet
power range: 50-250 watts RMS (1000 watts peak power)
frequency response: 20-1000 Hz
sensitivity: 87 dB
mounting depth: 3"
sealed box volume: 0.35-0.70 cu. ft.
ported box volume: 0.35-0.70 cu. ft.
To be continued...
Old Sep 28, 2007 | 02:35 PM
luke280's Avatar
Rockford Fosgate P3SD210 Shallow 10"
10" shallow subwoofer with dual 2-ohm voice coils
fiber cone reinforced with Kevlar with poly-ether-ester surround
shallow-design aluminum basket
power range: 100-300 watts RMS (150 watts per voice coil)
peak power handling: 600 watts
frequency response: 45-250 Hz
sensitivity: 83 dB
top-mount depth: 3-1/2"
sealed box volume: 0.4-1.0 cubic feet
ported box volume: 0.75 cubic feet
And of course:
Image Dynamics IDQ10V3.D4 Version 3 10"
Impedance: Dual 4 ohms
Power Range:50 - 500 Watts RMS
Mounting Depth: 5.75"
Mounting Diameter: 9.60"
Sealed Enclosure Range: .55cu.ft. - 1.1cu.ft
Ported Enclosure Range: 1.0cu.ft. - 1.5cu.ft.
Let me know guys what you all think I should get and I'll make sure to get a ton of pics. I don't wan't a seat lift. i listen to metal and hard rock. And Rap occasionally. SQ is higher in the food chain than SPL, but I just blew my last sub so I play them very loud! I don't want to change out amps to go louder so this will need to match up pretty good to the new sub(s). Everything else is stock. Next to go is the H/U, then the door speakers. HOOK A BROTHA UP!!!
PS, if you have another sub in mind, post a pic please.
Old Sep 28, 2007 | 02:56 PM
styxnpicks's Avatar
4 8's
Old Sep 28, 2007 | 03:05 PM
luke280's Avatar
Hmmm... Wonder where i could see one of those. Have you finished your box yet man?
Old Sep 28, 2007 | 03:22 PM
styxnpicks's Avatar
actually, I just did today, still need to do the trim ring but the box is sealed now
Old Sep 28, 2007 | 03:25 PM
luke280's Avatar
Cool man. Get those pics up.
But since I am not gonna swap out amps, which ones should I go with.
Old Sep 28, 2007 | 03:30 PM
styxnpicks's Avatar
brax, audison, tru, zed audio, zapco, genisis, sinfoni, among others.... oh wait, those are good amps.....
Old Sep 28, 2007 | 03:37 PM
luke280's Avatar
Old Sep 28, 2007 | 03:38 PM
styxnpicks's Avatar
go with two of the kenwoods
Old Sep 28, 2007 | 03:40 PM
98Expedition10's Avatar
Thumbs up
Out of the speakers that you had selected I would have gone for this one. Primarily because of your need for a shallow mount speaker, and because this unit is about twice as loud as the others (given similar circumstances)
Shallow mount speakers give up some conversion efficiency (Elect.>Sound)producing less sound per watt. If you can got over this point that you will need essentially twice the power required for similar speakers than they all are essentially the same. I prefer convex geometry speakers myself, but I can understand the need for fit in some vehicles.
sensitivity: 90 dB
Old Sep 28, 2007 | 11:50 PM
alfack's Avatar
Why not these?
http://mobile.jlaudio.com/products_s...p?series_id=15
Seems like they would be a good match for your amp. Two 4 ohmers, wired parallel. I'm running two 8 ohmers off a PDX 1.600. They sound pretty decent.
Old Sep 29, 2007 | 12:40 PM
Bartak1's Avatar
Get passive radiators and put squirrels in the box to push them in and out.
Old Sep 29, 2007 | 03:57 PM
mSaLL150's Avatar
the kenwood doesnt even dip below 35Hz you can find comps that will hit lower frequencies then that....
i like my subwoofers to hit the low lows. go with the IDQ no doubt. if it is too deep, get the v.2 its more shallow.
Old Sep 29, 2007 | 05:24 PM
styxnpicks's Avatar
35 is the low lows, anything below needs massive cone area to hit
Old Sep 29, 2007 | 06:23 PM
mSaLL150's Avatar
10" IDQ V.2
* Size: 10 inch
* Rec. Sealed Box Dims: 0.35 - 0.70 cu. ft.
* Rec. Ported Box Dims: 0.75 - 1.00 cu. ft.
* Free Air Usage: not recommended
* Sensitivity: 89.9 dB
* Frequency Response: 10-150 Hz
* Recommended RMS Power: 250W
* Peak Power Handling: 500W
* Impedance: dual 4 ohms
i wouldnt call the IDQ massive. my sub isnt a very good one or massive at all and it plays 20Hz test tones.
