8" subs in the doors
Old Sep 11, 2007 | 08:08 PM
lizardbreath's Avatar
ok i have been searching on this for a while would it work to put 8 " subs in my rear doors of an 07 xl reg cab
i found a pair of free air subs to use
http://www.crutchfield.com/S-xUBqhug...20&I=2064SSMB8
and please dont tell me how dumb this is or why i am doing this. i want a clean look and some thump without taking up any room
thank you
Old Sep 11, 2007 | 09:17 PM
Bartak1's Avatar
https://www.f150online.com/forums/sh...ighlight=doors
Ignore the first 5 post...
8's are going to be tight in our back doors I think. There isnt really decent way to get a baffle that an 8 will fit on....a pair of 6.5 subs would fit a whole lot better...
Old Sep 11, 2007 | 09:23 PM
mSaLL150's Avatar
its possible, but will require a lot of work. probably better to stick with 6.5s (like Bartak said). i dont know how big the doors are on the red cabs.
maybe build a small enclosure for behind your seat that wont take up much space just put a nice 10 in it?
Old Sep 11, 2007 | 11:33 PM
styxnpicks's Avatar
thank you
how much are you willing to cut?
Old Sep 11, 2007 | 11:51 PM
Bartak1's Avatar
x2....that pretty much determines if its possible or not, and it so how far you can go with it.
Old Sep 12, 2007 | 04:02 PM
ummm not sure depends on how much work it will be im going to look into this a bit more when i have time. but ill cut as much as i have to as long as i can still fit the door cover on
Old Sep 12, 2007 | 04:27 PM
MmmBuckles's Avatar
those things are gonna rattle like hell.
Old Sep 13, 2007 | 06:09 PM
Impact9's Avatar
I'd go with 6.5 woofers in the door. You're pretty much going to have to build out and I'd question whether or not you'll get the door panel back on. Thing is the normal mounting depth is pretty shallow. Not terribly shallow but I don't dare slam my back doors with the windows down cause I can heard the glass hit against my MOMO's in there. Now if you're willing to pull out all the window junk and make the glass stay up permanent then you'd be pretty much home free to go with 8's or shallow 10's plus one hell of a load of sound deadener and fiberglass to make it sound good with out rattles.
Old Sep 13, 2007 | 08:03 PM
Bartak1's Avatar
Reg cab back doors....windows dont go up or down
Actually a decent mounting depth in there because of it too. If the windows did go down it would be damn near impossible.
Old Sep 14, 2007 | 05:17 PM
remmy's Avatar
Ill concur, 6.5's would be great. I know JL makes those subs and I think rockford does too. While your at it go to the hardware store and grab a big ol'e role of dynamat like material and deaden the living crap out of those doors. Its a little thinner but 3x cheaper and just as effective. Dynamat is a complete rip off.
