how to bridge an amp properly
Old Aug 20, 2007 | 04:49 PM
king ranch's Avatar
i have a 2 ch 1200 watt sony xplod amp, i was wondering how to bridge it, some people have both positive terminals hooked up, and others have a negative and positive hooked up, and others have the pos and neg hooked up and a wire connecting the other ops and neg terminals.
thanks
Old Aug 20, 2007 | 05:14 PM
styxnpicks's Avatar
the question is why you want to bridge your amp
Old Aug 20, 2007 | 05:15 PM
jmt0645's Avatar
most amps have it printed on the heatsink which terminals to use. but, its usually the negative from the right channel and the positive from the left channel. no other connections are needed.
Old Aug 20, 2007 | 05:38 PM
Bartak1's Avatar
Usually left positive and right negative
As said, it will say right on the amp. Usually lines drawn on the amp connecting the two terminals you need to use. Usually says "BRIDGE" on it
Old Aug 20, 2007 | 06:01 PM
king ranch's Avatar
i am briding the amp to get more power from it thats why above the left pos and right neg it has the letters btl above the terminal whats that mean
also i was wondring why do my subs get louder and have more bass if i unplug the red rca cable that goes into the amp
Old Aug 20, 2007 | 06:32 PM
Bartak1's Avatar
Bacon tomato and lettuce???
No idea what the BTL stands for.
Try throwing in a differnent pair of RCAs and see what it does...
Old Aug 20, 2007 | 06:48 PM
MGDfan's Avatar
You said 'subs' right?
Perhaps they are out of phase; pulling one i/p cable let's one run unmolested by the output of the other.
bubba
Old Aug 20, 2007 | 06:49 PM
styxnpicks's Avatar
if your subs ar getting louder when you unplug the red rca cable because your subs are wired out of phase..... before you try bridging the amp try reversing the wires on one of the channels... alot of beople think bridging is end all be all of their problems... its really not tho
Old Aug 20, 2007 | 06:59 PM
yamaharhino's Avatar
This is how you bridge a sony xplod amp, and a sony xplod amp only. Find the tallest bridge you know of... And throw it off the side.
Old Aug 20, 2007 | 07:07 PM
Bartak1's Avatar
bubba
Doh, good catch. Could be it.
Amen
Old Aug 20, 2007 | 09:28 PM
jmt0645's Avatar
my bad:o its my dislexia
Old Aug 20, 2007 | 09:39 PM
DRJ's Avatar
DRJ
another BTL sugg.
Bridging The Lines...who knows....I'm bored outta my mind
Old Aug 20, 2007 | 10:40 PM
F150Truck'in's Avatar
sounds closer than
must have been around CJ's dinner time...
Old Aug 20, 2007 | 10:51 PM
Bartak1's Avatar
Originally Posted by F150Truck'in
sounds closer than
Its always around my dinner time. I love food
Old Aug 21, 2007 | 11:46 PM
6spdcoupe's Avatar
BLT = Balanced Line Transmitter. Obviously NOT the case when we're talking Sony though.
To the OP .. 99% chance your subs are out of phase, follow instructions above.
