couple of questions
Old Aug 20, 2007 | 12:21 AM
TRUEBLUE2004's Avatar
couple of questions
Will this sub fit in a supercrewsound box? http://www.soundsolutionsaudio.com/p...on/icon10.html
Also if I run two subs rated at 400 watts rms off of a single channel amp does it need to be rated at 400 watts or 800?
Old Aug 20, 2007 | 12:55 PM
Bartak1's Avatar
No idea if it will fit.
If you are running two 400 wrms subs and want to run them at full RMS, then you would need 800 watts at whatever load your subs are. Power is split between the two.
Old Aug 20, 2007 | 01:09 PM
SAtownTX's Avatar
it might fit. mounting depth of sub is 6 inches and max you can get with a supercrew sound box it 5 7/8 with the added mounting depth mod. i would email them and see.
Old Aug 21, 2007 | 04:55 PM
I e-mialed them but no response yet.
thanks I thought it was rms / # of subs. My local shop said it was the same to both subs so a 400 watt amp would send 400 watts to both subs I was like .
Old Aug 21, 2007 | 11:35 PM
styxnpicks's Avatar
that 10 looks about the same size as my old RE sx 10's.... wont fit without a seat lift
