10w1v2-amp question
10w1v2-amp question
I have a JL 10w1v2 in a sealed box under my rear seat in my 04 SCAB. Im using a 10 year old Pioneer amp pushing 125X1 to this sub. It hits pretty good, but was wondering if a new amp, maybe a little more power will make a noticeable difference? The sub is rated at 125rms...any suggestions regarding a new amp and how much rms I can push through this single 10? Im a novice at this and would really appreciate any feedback.
If your pushing 125 watts to it, then your doing perfect.
Unless you go up to around a 250 watt amp or so you really wont notice a difference-not enough to justify the cost anyway...but since you admit that you are a novice about this stuff I personally wouldnt reccommend you to send a speaker double is rated power.
If you know what to listen for and now to set things up correctly, you would be fine...I dont know how much of a novice you are though...
Originally Posted by EW_
I normally try to run 200W RMS on the 10" & 12" W1v2. An old Pioneer 125W amp is probably not doing the woofer justice.
