rear view mirror
I havent ever looked to hard, but I dont believe there is a way to tighten it to keep it from doing that.
If your the only one who drives the truck, MAYBE you could set the mirror right where you need it then put a dab of superglue on the ball/joint and see if that would keep it in place?? I dont know if that would work or not for sure though...
A whole new mirror assembly might fix the problem too. New mirrors are usually pretty stiff compared to an older one thats been moved around a lot. Them mirror in my new truck didnt even vibrate at first, but it is starting to loosen up a little now. No where near as bad as it was in my old truck.
So that could fix it maybe.
Or else rip the bish off and use the side mirrors
Just get a new Rear View from the ford dealer, not one of those worthless parts store ones....
I'm a Master Autoglass installer and can tell you its pointless trying to do anything to yours to fix it....the pivot ball is pressed in to a socket with a plastic insert in it, no fixeee, just replaceeeeee.. LOL
