New purchase
Old Jul 23, 2007 | 06:55 PM
Fordwitflows's Avatar
New purchase
I just ordered a small sytem for my truck and I would like your input
-2 10" Kicker CompVR CVR102 Dual 2 Ohms
- MA Audio M1889I 800 Watt RMS Mono-Block High Performance Amplifier
-Box from Supercrewsound.com for under rear seat
Opinions?
Old Jul 23, 2007 | 07:02 PM
mSaLL150's Avatar
what are the power ratings for that amplifier?? you bought dual 2ohm subs, meaning that when you wire them in a mono load to you amplifier, you will be able to run a .5 ohm load (doubt your amp is stable here), a 2 ohm load (your best bet, hopefully amp has enough power at this resistance) or a 8 ohm load (wont get much power at all).....
i dont know much about the supercrewsound box, hopefully its like my musicmoose box with sturdy 3/4 MDF. you may also want to put rubber stoppers or bumps under your box to give your sub more room for cone movement.
Old Jul 23, 2007 | 08:34 PM
Bartak1's Avatar
Should work together nicely.
