Kicker L7
Kicker L7
I saw a guy that had 2 12'' kicker L7 in his 2002 F150 at a show but he had them underpowered because the amp he was using was too small for the to L7, what would be a good amp to push two 12'' L7's that are rated at 700 watts rms or would some Kicker solo X 12'' would be better because they are over 1000 watts rms but what good amp with push those suckers?
be careful man, hifonics amps are very reliable and put out a ton of power. you put 1600 RMS into a kicker L7 10" your going to fry it. frankly if you throw 1600 RMS at both subs (800 each) they still might blow. ease up on the power gains for sure.
kicker 1250.1....1250watts@ 1 ohm stable...this will power your two L7's perfectly........ported box?
thanks im tryint go get a used seatlift for my 2005 f-150 because a new one cost over $150 shipped and then i have to customize a box and add two L7's, since imma use a seat lift should i go with 2 10''s L7 or 2 12''s L7 they are about the same price
