Redoing sub stage again.....
Old Jun 20, 2007 | 10:43 PM
F150Truck'in's Avatar
Well, got my seat lift today and must agree, the instructions are flat out worthless....I'll play with it tomorrow evening....
parts express order is here also with jet black carpet and 8Ga. terminal cup, speaker mounting screws for MDF, speaker gasket tape....
Getting there, still got to go to Lowe's for MDF....
Old Jun 21, 2007 | 09:33 PM
Pulled the back seat upper and lower this evening to get a idea on the install, test fitted the seat lift brackets.... Damn, did the designer even have a F150 not a single piece will fit without mods something.... unless I install the rail on top of the brackets to raise the upper with the lowers, thats what I'm going to do, more room and air flow on the amps
Need the get 3 pieces of flat bar steel .125 x 1.5 X 4.0 inches and mount on rear cab wall to catch the upper seat top clips, small dia. 3.0 inch bolts for the upper seat belt cover... simple enough...I hope....
Old Jun 21, 2007 | 09:38 PM
Bartak1's Avatar
Dontcha love it when things go in exactley like they are supposed to
Old Jun 22, 2007 | 01:13 PM
Jwool15's Avatar
yea the instructions do suck.. have fun
Old Jun 22, 2007 | 09:27 PM
ok,
3 hours this evening drilling and filing out brackets to get this Quility LMI Kit to haft way line up, but the lower seats are in....
I had to get the lower seats finished tonight so I can drive the the Ford dealer in the morning for state inspection, oil change, tire rotation.... can't drive with those cab mount bolts out....
Old Jun 23, 2007 | 11:05 PM
Still working on it...
Made Custom Steel Brackets to catch the upper seat clips 2" X 4" X .125 Steel Flat Bar with 2- 1/4" Body Rivets
May unbolt that rusty bar and paint it black as you can now see it in between the seats...
Old Jun 23, 2007 | 11:09 PM
No problem fitting a 12" Rainbow Profi now, hell, I could fit a small body under that seat..
amazing how much more room there is with just a 2.5" lift....
Old Jun 24, 2007 | 05:17 PM
Bartak1's Avatar
Looking good
At least you finally got that lift in huh I tell ya, after all I hear about those things I dont think I would ever buy one lol. It looks nice at least.
Get that thing in there now.
Old Jun 24, 2007 | 08:03 PM
All finished on the seat lift and it now meets my ****, picker than picky approval.....
You all know I had to paint the rusted bar black, no way that was going to slide....
Old Jun 24, 2007 | 08:15 PM
Originally Posted by Bartak1
Looking good
Thanks Bart....
Bart, man, I must say, this is by far the worst fitting piece of Sh$t I ever installed in a truck or car that is custom made to be vehicle specific....
basicly 3 days to install, I know I'm ****, but damn.....
anyway, just took sizes for the box and getting ready to calc air space.. looks like 2.75" for Xmax and I'm going to route the box for recessed driver..
No way this driver going to be anyway near the carpet....
Old Jun 24, 2007 | 08:19 PM
Bartak1's Avatar
So when will you get around to building that box?
Also...off topic, but I just noticed your seats are black and everything else is grey Did it come like that or did you put the leather covers on? I want leather in my reg. cab...
Old Jun 24, 2007 | 08:37 PM
I installed them about a year ago, OEM Black Leather takeoffs from Ebay, they are not hard to install at all, also installed seat heaters on the fronts while I had to covers off.....
working on box details as we speak.... should be cutting MDF Tuesday evening, or at lease, thats the plan...
Old Jun 28, 2007 | 08:45 PM
I got the box designed, been though 3 revisions this week using cardboard and plexiglass templates, but I got it pegged now, I think...
Only thing i'm in question on is the leg, I want 2 3/4", but its looking more like 2 1/2" for fit... I'll make 3/4, can trim off to 1/2 if needed....
I'll start building this weekend.....
Old Jun 28, 2007 | 10:56 PM
Bartak1's Avatar
Looking good...I think you forgot to add the volume of the sub though
Depending on how much space your sub takes up you might end up with only a 1.3 cu ft box after displacement. You can always add a little width, I really wouldnt worry to much though.
Or maybe you do have it figured in and I just dont realize it.
I wouldnt worry to much about the leg height either. I think I only have 2.5 or 2.75 inches between my box and my floor and have zero problems with it.
Old Jun 29, 2007 | 11:18 AM
BestNTx's Avatar
Way too much planning man, just measure up and build
