FI Sub install in 06 Screw... LOTS OF PICS!!
Old May 22, 2007 | 09:21 PM
mmb2's Avatar
Ok finally got my FI 10" Q's installed, here is what i have
2006 F150 Supercrew
Head Unit - Kenwood DDX-7017 Screen
Amp - MA Audio HK4000D
Subs - 10" Q D2, no upgrades.
2 headrest monitors and a PS2
Wiring
0/1 Gauge to amp power/ground
8 gauge to speakers
a mile of audio/video cables
Box is .5 CF Sealed per sub, everything is contained under back seat! i did have to lift the seat
2.5" with a high rider seat kit.
FOR MORE PICS CHECK OUT MY GALLERY
Old May 22, 2007 | 10:27 PM
Bartak1's Avatar
Looking good man.
So how much power you pushing to them? 2k watts?
Not a huge MA fan, but I must say the cover on that amp is pretty cool
Old May 23, 2007 | 12:35 AM
edwardsjr1's Avatar
how's it sound. Im lookin to do the same thing.
Old May 23, 2007 | 02:04 AM
Impact9's Avatar
Originally Posted by Bartak1
Looking good man.
Yea it is pretty spiffy. Odd power ratings though:
RMS Power @ 14.4V: 50W x 1 @ 4 Ohm, 3600W x 1 @ 2 Ohm
RMS Power @ 17.0V: 75W @ 4 Ohm, 4000W @ 2 Ohm
Still looks pretty good even with that hack job on the rear liner.
Old May 23, 2007 | 12:53 PM
jmt0645's Avatar
the 17.0V is if your running 16.0V batteries for competition.
Old May 23, 2007 | 02:30 PM
luke280's Avatar
Never thought of doing this! Is there a special bolt (alloy wise) that should be used?
Old May 23, 2007 | 02:38 PM
Bartak1's Avatar
Just your standard ol' bolt and nut-if its conductive it will pretty much work. Works like a charm, better that those d@mn terminal cups.
Old May 23, 2007 | 03:06 PM
Impact9's Avatar
Course you know not all terminal cups are created equal. Speaking of which I still need to order mine.
Some use a compression sort of like the better subs have. I wish KNU had Kompression style cups.
Old May 23, 2007 | 03:10 PM
Impact9's Avatar
ahh forgot about that side of the coin.
Old May 23, 2007 | 05:58 PM
mmb2's Avatar
i run the gain 3/4 way up, it will overpower the q's so the amp is more than 2kw, i have enough bass to flex my dash and move the steering wheel, sounds awesome, i love FI subs.
Impact9 - thanks im glad you like my hack work
luke280 - i used a 5/16 stud and nuts for my speaker terminals, at the hardware store.
Old May 29, 2007 | 12:04 AM
Jwool15's Avatar
im glad you're happy. I hate FI and will never use another one of their products again!
Old May 31, 2007 | 04:26 PM
Nicks700r's Avatar
Dude that looks sweet, I bet it hits awesome! nice job!
If you have the bass up will it mess up the PS2 while in use?
Also great idea on the bolts.
Regarding the amp being mounted to the rear wall.
How come everone cuts out the carpet? I'm about to install my stuff next week and was just curious.
Is it a fire hazard? will it cause the amp to hold in to much heat? It seems like if your not adding dynomat or something that you would want it for sound deadining?(sp?)
Old May 31, 2007 | 04:43 PM
jmt0645's Avatar
for me it was cause the carpet was to thick to keep on.
Old May 31, 2007 | 05:06 PM
Nicks700r's Avatar
ok, I havn't started pulling stuff yet and seeing what my clearences will be. But if you could have left it would you?
Old May 31, 2007 | 05:28 PM
renglander's Avatar
Sweet Set Up!!
Did you record the dimensions you used for the box? I am doing something similar in my 04 screw.
