FI Sub install in 06 Screw... LOTS OF PICS!!
Old May 31, 2007 | 06:33 PM
mmb2's Avatar
Originally Posted by Nicks700r
Dude that looks sweet, I bet it hits awesome! nice job!
If you have the bass up will it mess up the PS2 while in use?
Also great idea on the bolts.
Regarding the amp being mounted to the rear wall.
How come everone cuts out the carpet? I'm about to install my stuff next week and was just curious.
Is it a fire hazard? will it cause the amp to hold in to much heat? It seems like if your not adding dynomat or something that you would want it for sound deadining?(sp?)
thanks! the playstation works when the bass hits, the kids dont like playing it when i crank it up so it is usually down.
I cut my rear liner because it was not flat it looked like it was molded around a box - stuck out from the rear wall about 4 inches. I would have made a fancy amp rack, but seeing how i dont have x-ray vision and dont drive around with the seat off i just mounted it to the rear wall!
Good luck on yours i am very pleased with mine!
Old May 31, 2007 | 06:36 PM
mmb2's Avatar
Originally Posted by renglander
Did you record the dimensions you used for the box? I am doing something similar in my 04 screw.
i can take some demensions, i just fabed it up while i was making it, it is 13" deep and 9" tall in the front around 54" wide
Old May 31, 2007 | 08:46 PM
jmt0645's Avatar
ok, I havn't started pulling stuff yet and seeing what my clearences will be. But if you could have left it would you?
nope. more airflow back there means a cooler amp. cooler amp=longer more reliable play time.
Old May 31, 2007 | 09:00 PM
renglander's Avatar
Did you calculate the volumn required for the subs? If so, did you divide the box somewhere?
Old May 31, 2007 | 09:10 PM
mmb2's Avatar
i needed .5~.6 cf per sub after all displacements, the box is split into 2 chambers each chamber is right at .65 cf (.12 displacemnet per sub) my chamber divider is under the ps2 it is off center a little bit to make up for the lost area around the seat frame.
i used 3/4 mdf for the whole thing, i'll measure everything and post the info tommorow.
Old May 31, 2007 | 09:15 PM
mmb2's Avatar
by the way your wheels and tires in your gallery are SWEET!!! i almost bought the pro comps over my toyos, how do you like them?
Old May 31, 2007 | 09:19 PM
renglander's Avatar
i appreciate it alot....
Old Jun 1, 2007 | 09:06 PM
mmb2's Avatar
OK my box is 13" deep, 48.5" wide, 7 3/4" tall in front - 6.5" tall in rear, the area under the ps2 is 3.5" tall. Hope that helps if you need more info just let me know.
Old Jun 1, 2007 | 11:59 PM
renglander's Avatar
Thanks, I can work with it. I appreciate it.
Old Jun 2, 2007 | 08:27 AM
renglander's Avatar
The pro comps are nice. As a matter of fact I am still looking to sell those wheels and tires. My wife is almost due with our baby and she hates having to get up into the truck. I am going to lower it as soon as I get these sold. I am selling them for $700 not including shipping.
Old Jun 2, 2007 | 02:21 PM
mmb2's Avatar
wheels and tires for $700? Man someone will be all over that, i would put up a post in the wheels and tires section.
Old Jan 6, 2010 | 11:53 PM
trojanman22's Avatar
PLEASE tell me you have the exact dimensions for the box. ive been trying to fab something up similar for a while but its exctremely frustrating....
