Custom Sub Box
Old May 15, 2007 | 03:57 PM
Iam4st8's Avatar
are you trying to cram 2 10'' subs under a 3/4 split back bench seat in a 2002 screw? if so. good luck. I could only fit one (with enough airspace). If you force 2 in there, it might sound like ***.
I have one ten under the driver side back seat and the amp under the other rear seat. But i've recently added 2 more 10'' subs in the middle seat and on the floorboard in the middle, like a make-shift console. It dosnt look bad, and sounds amazing with those 3 10''s
Old May 15, 2007 | 03:58 PM
Iam4st8's Avatar
However, i'm not familiar with the 2002 set up, i have a 2003. If you have 3 seperate seats in the rear or its split a different way you may be able to fit them. All i know is the bars under my seat wont allow me to put a sub on the other side.
Old May 15, 2007 | 04:05 PM
Dallasstars10's Avatar
Have u not seen the boxes that hold 2 subs one is on the drivers side and the other is behind the passenger side back seats. I have a SCAB btw.
It can be done as long as the subs are pretty good i belive.
Any objections ne one/
Old May 16, 2007 | 08:57 AM
Since i don't think anyone saw this,
When i am making the circular "10 inch" cut out am i making this exactly 10 inches or should i make it a little less?
Old May 16, 2007 | 09:32 AM
firedognick's Avatar
You will have to figure out what subs that you will be using because every one makes them a little different, for instince the "JL W7" 10" sub needs to have a 8.74 in. / 222 mm hole for it.
Old May 16, 2007 | 09:38 AM
TBDAugs's Avatar
If you are buying new subs, they will come with templates that you would use to determine what to cut and drill. Don't cut the MDF before you get your speakers, then use either the speakers themselves, or the templates they come with to decide how to cut the hole for them.
IDQAugs
Old May 16, 2007 | 03:50 PM
Are you supposed to use Dynamat inside the sub box or outside or both or it is just preference?
Sorry for all the newbie questions guys.
Old May 16, 2007 | 05:27 PM
051fdrof's Avatar
I don't know how your '02 compares to my '06, but I have some pretty detailed drawings in my gallery for a dual 8" box that fits great under 2/3 of my rear seat.
Old May 17, 2007 | 12:02 PM
Iam4st8's Avatar
oh, its a Scab, then you can do it dallas. 2 10''s can fit under that seat, but not in the screw, (what i thought you had)
Old May 17, 2007 | 01:09 PM
TBDAugs's Avatar
I wouldn't bother with matting the inside of your sub box. But you may want to consider putting no more than one pound of polyfill in it if it's under 1 cubic foot.
The outside just cover to match your interior, carpet or paint.
SonicAugs
Old May 17, 2007 | 01:43 PM
Okay Thanks a bunch. I think im going to start building the box this weekend. And after my dad decides if i can buy the subs im giong to go with Image Dynamics 10"
Old May 20, 2007 | 08:56 PM
Started building the box today and yesterday. Looks good next weekend i need to put all the glue and seal all the holes and then it should be good. GOtta order those ID Subs too!!
