Soooo Confused....
Old May 15, 2007 | 01:45 AM
  #31
cakeeater2's Avatar
i didn't think that you always had to wire every vc, so couldn'e he leave one out on both subs to achieve a 2ohm load?
Old May 15, 2007 | 01:57 AM
  #32
Impact9's Avatar
you don't have to but there is a very noticeable difference in sound.
Old May 15, 2007 | 07:22 AM
  #33
usmcairwinger's Avatar
I have the same subs and am using a Rockford Fosgate 450.2 amp. The subs sound really good with this amp. Just thought Id let you know what I am using since I have the same subs
Old May 15, 2007 | 09:37 AM
  #34
styxnpicks's Avatar
not only that but you can only run half of the power then
Old May 15, 2007 | 02:19 PM
  #35
Bartak1's Avatar
And your driver specs change quite a bit when only running one coil instead of two.
No reason to only run one vc.
Old May 16, 2007 | 04:53 PM
  #36
cakeeater2's Avatar
my bad, i've always hooked up both vcs on dual vc subs..just an idea since he was so determined to run at 2 ohm.
