The Subwoofer Thread
Old Apr 27, 2007 | 08:50 PM
byoon001's Avatar
I'm bored at work and with all the same reoccuring threads about which sub to get, why not just make a list!
Not being a sound guru like the rest, I'd like to just get this thread off the ground. Here's a few subs that I found while I searched for mine. Feel free to add to the thread, post reviews and what not!
RL-i: Awesome sub, I own the 10'' driver myself and it sounds awesome. Running it off of 250 RMS in a supercrew box. I feel the 250 and the box is limiting the sub itself. Would recommend a seatlift for those wanting the 10''.
Specs For 8''
Dual 4 Ohm
Qts: 0.280
Qes: 0.316
Qms: 2.515
Fs: 28.9 Hz
Re: 7.4 Ohm
Ls: 2.961 mH
Rp: 4.777
Vas: 21.98 L
Mms: 77.97 g
Cms: 387.1 u
Bl: 18.24 T*m
SPL: 84.11 dB
Sd: 0.020 m^2
Xmax: 18.3 mm
Measurements
Mounting Depth: 15.3 cm
Depth: 15.2 cm
Basket Width: 18.5 cm
Weight: 18 lbs
Magnet Width: 15.6 cm
Mounting Cutout: 18.8 cm
Displacement: 0.08 cu ft
TC-1000: Buddy owns a 12'' driver, running 560 watts to it and it sounds great! More oriented towards SQ than SPL.
10" TC-1000
Qts 0.228
Qes 0.242
Qms 3.803
Fs 21hz
Res 3.70Ω
Ls 2.48mH
Lp 3.28mH
Rp 3.15Ω
Dia 195mm
Vas 57.7l
mms 129g
cms 458um/N
bl 15.4T*m
Spl 84.8dB
Measurements
10TC-1000 9.50" 10.65" 0.65" 5.7" 0.08ft3 19.2lb
Aurasound MR 12
Sensitivity: 84dB @ 200 Hz
Power Capacity, RMs: 400W
Power Capacity, Peak: 1600W
Freq Range (-10db): 1.5kHz
Xmax: 54mm
Res Freq: 27hz
Voice Coil DC resistance: 3.5ohms
Total Q: .43
Mech Q: 7.1
Eletrical Q: .45
ID Max 12
Nominal Impedance (IMP) 2 / 8 ohms
DC Resistance (Re) 1.95 / 7.9 ohms
Resonant Frequency (Fs) 20 Hz
Electrical "Q" (Qes) .404
Mechanical "Q" (Qms) 2.18
Total "Q" (Qts) .341
Equivalent Volume (Vas) 5.81 ft3
One Way Linear (Xmax) 24.6 mm
Cone Area (Sd) 545 cm2
Sensitivity (Spl) 88.1 dB
RMS Power Handling (Pwr) 200 to 1000
Speaker Displacement .12 ft3
Overall Dia. 12.5''
Depth 8.25''
Mount Dia. 11.0''
Magnet Dia 6.5''
JL 12w7
Free Air Resonance (Fs): 27.2 Hz
Electrical “Q” (Qes): 0.514
Mechanical “Q” (Qms): 7.807
Total Speaker “Q” (Qts): 0.482
Equivalent Compliance (Vas): 2.33 cu. ft. / 66.0 liters
One-Way, Linear Excursion (Xmax)*: 1.15 in. / 29 mm
Reference Efficiency (no): 0.249%
Efficiency (1W/1m)**: 86.2 dB SPL
Effective Piston Area (Sd): 84 sq. in. / 0.0542 sq. m.
DC Resistance (Re): 2.47 ohm
Nominal Impedance (Znom): 3 ohm
Thermal Power Handling (Pt): 750W
Driver Displacement: 0.14 cu. ft. / 4.0 liters
Nominal
Diameter Overall
Diameter (A) Mounting Hole
Diameter (B) Bolt Hole
Circle (C) Magnet
Diameter (D) Mounting
Depth (E)
12 in. / 305 mm 12.5 in. / 318 mm 10.5 in. / 267 mm 11.27 in. / 286 mm 7.5 in. / 191 mm 9.5 in. / 241 mm
Stereo Integrity Mag 12''
T/S parameters: 12 inch
Re (coils in series) 3.5
Fs 30.2
Le 3.5
Qms 4.7
Qes 0.45
Qts 0.41
Cms 121
Mms (grams) 228
Vas (liters) 39.7
Sd (cm^2) 480
BL 18.35
SPL (1W/1M) 85.7
Power handling RMS 900
Stereo Integrity BM 10'' & 12''
T/S parameters: 10 inch 12 inch
Re (coils in series) 7.8 7.8
Fs 27.1 28.3
Le 3.4 3.4
Qms 3.08 3.55
Qes 0.31 0.38
Qts 0.29 0.34
Cms 204 158
Mms (grams) 101 128
Vas (liters) 52.5 83.6
Sd (cm^2) 303 480
BL 21.7 21.9
SPL (1W/1M) 87.4 88
Power handling RMS 400 500
Polk Momo 10''
Electrical
Overall Frequency Response 24-200 Hz
Nominal Impedance 4 ohms
Minimum Impedance 3.25 ohms
Power Handling (continuous) 300 w
Power Handling (peak) 600 w
Efficiency 86 dB
Voice Coil Diameter: Driver 2" (5.08cm)
Magnet Weight 45.00 oz.
Driver Mounting Depth
Top Mount 5-3/4" (14.61cm)
Bottom Mount 6-1/4" (15.88cm)
Cut-out
Driver Cut-out Diameter 9-1/16" (23.02cm)
Old Apr 28, 2007 | 12:57 PM
Bartak1's Avatar
If we could find a way to organize this, and if this thread would take off, its not a bad idea. Maybe list some specs along with it such as power rating, coil configurations, mounting depth is a big one here, any other specs you'd like to post up (Sd, Xmax, Vas, blah blah blah)
Old Apr 28, 2007 | 03:27 PM
dconder's Avatar
Everybody may have their favorite subs and you will get a lot of different opinions so here is mine.
If depth were no object, 12" Image Dynamics IDMAX. Still the best sub I have ever owned or heard.
For the F-150 and space limitations, the Stereo Integrity Mag 12" with a seat lift. Incredible sub for less than 7" or mounting depth.
With no seat lift, Image Dynamics IDQ 10" will fit and maybe even the 12" might fit. One of the best SQ subs ever. Does not need a lot of power either.
Old Apr 28, 2007 | 05:50 PM
rowdyt's Avatar
I agree 100% ... just some cant afford a couple si magnum 12's ( bartak, brypink2, dconder ...etc).
Old Apr 28, 2007 | 07:01 PM
brypink2's Avatar
Here's my short list (no particular order):
AA Brahma 12"
Aurasound MR 12"
IDMAX12
JL Audio 12W6v2 & 12W7 (<---for some reason, I still like this sub)
SI MAG 12"
Someone else can post specs and pics.
There are other very nice subs...but these would be the ones I pick from.
***BTW, the new IDQ (v.3) looks promising...93 dB efficient.***
Old Apr 28, 2007 | 07:03 PM
styxnpicks's Avatar
AA Brahma 12"
Aurasound MR 12"
IDMAX12
SI MAG 12"
12's....
pfft
real men play with 8's
Old Apr 28, 2007 | 07:06 PM
brypink2's Avatar
Originally Posted by styxnpicks
12's....
pfft
A "real" man would put a 1 in front of that 8.
Old Apr 28, 2007 | 11:34 PM
Impact9's Avatar
Now that's funny
Aside from a sheep load of old school 12's I just got back into the CA realm.
So recently I've went with
10's
Polk MOMO 1024
SI BM10 - LOVE IT
12's
SI BM12 - FRIGGEN AWESOME
http://forum.realmofexcursion.com/forumdisplay.php?f=54
^ covers almost all descent 12's
Old Apr 29, 2007 | 07:16 AM
styxnpicks's Avatar
lol I sold my 18 to buy my 8's and the bedrug
Old Apr 30, 2007 | 05:28 AM
byoon001's Avatar
updated, would only let me post 4 pictures so I'll get the rest up later.
