2006 factory sub wireing?
Old Apr 18, 2007 | 10:48 AM
Ignerence's Avatar
Hey, I have a question, I have a 2006 F-150 crew cab, with the factory sub under the rear seat, I am replacing this set up and need to know what the 5 wires on the plug are each for, does anybody have a diagram or way to tell? I figured out the power and the ground, but the three small ones I dont know about. I figure one is a common ground for the audio input, and the other two are the right and left inputs, but I need to know what one is what. Thanks for any help, if more info is needed just let me know.
Phill
Old Apr 18, 2007 | 11:08 AM
troberts6874's Avatar
i would guess....the hot and ground power the amp you know that...the other three...well two go to the speaker and one is a remote on/off switch for the amp...i think usually purple or blue....just a guess, but i think that should be it...i am sure someone here will know.
so the last one wire should be the amp on/off switch....your new amp will need it to come alive and turn off when radio off so as to not kill your battery.
Old Apr 18, 2007 | 01:52 PM
MGDfan's Avatar
Hi.
Check this out ....
https://www.f150online.com/forums/sh...d.php?t=278790
I'd normally just ask you to search, but not in this case ... you'll see why in that thread LOL!
Good luck & hope this helps.
Cheers
Bubba
