Preliminary Box Plans for 04 and up Supercrew and Cab.
Old Mar 2, 2007 | 06:55 PM
THASQGOTME's Avatar
Registered User
I know everyone is always wanting dimensions for sub enclosures on here. I have looked myself on this forum and compiled on what I think will work perfectly for my 2006 F-150 Supercab, based on several different dimensions posted by other builders on this site, especially Dupuis' dimensions. Don't use these for definite measurements, just a rough idea, as I am building my enclosure this weekend, and will let everyone know if everything fits as it should. The blacked out portions are just legs at the ends that are 7" long and 1.5" tall.
Old Mar 3, 2007 | 04:15 PM
THASQGOTME's Avatar
Registered User
Forgot the bottom!
Old Mar 3, 2007 | 06:54 PM
byoon001's Avatar
How were you able to fit the back height (4.75) in? I had trouble shoving that sucker in there.
-Ben
Old Mar 3, 2007 | 10:48 PM
THASQGOTME's Avatar
Registered User
I still have not built the box. I am building it tomorrow morning. These are just preliminary drawings. I got the 4.75" height in the back from Dupuis' enclosure dimensions that he already built.
Old Mar 3, 2007 | 10:56 PM
anaheim_drew's Avatar
Originally Posted by THASQGOTME
Forgot the bottom!
I think its 52" long. But I measured mine and it is 50" What is your airspace?
Old Mar 12, 2007 | 11:55 AM
Dupuis's Avatar
If that's the size for the back I posted, it will and does fit. It will also allow you to still lift you seat up and down.
Old Mar 12, 2007 | 12:39 PM
051fdrof's Avatar
THASQGOTME - Did you build your box? Did it work? Pics?
Old Mar 12, 2007 | 08:19 PM
THASQGOTME's Avatar
Registered User
I did build a box. But I was all hungover and my dumbass added 3/4" to the rear height, so I don't know as of yet. I am pretty sure it will fit if you take down the rear height a little bit all the way across.
Old Mar 12, 2007 | 09:33 PM
Bartak1's Avatar
Old Mar 13, 2007 | 12:13 PM
051fdrof's Avatar
So you made the rear height 5.5"? Nice. Easy enough to do with a headache. Let us know how it turns out.
Old Mar 16, 2007 | 10:03 PM
THASQGOTME's Avatar
Registered User
I did build a box. But I did not built the box I posted because I had no more room for my amp. I already put them behind the rear seat, and it wouldn't fit under my front seats. The 4.75" in the rear fits like a charm. I just used Dupuis measurements to build my box for 2-8" Arc Audio D4's. These things bang for 8's. Thanks Dupuis for the dimensions. And I know now that the dimensions I posted will work. So give it a shot.
Old Mar 19, 2007 | 02:19 PM
Dupuis's Avatar
No problem, glad it worked out for you. By the way, at the time I built this box, I built 2 of them. One I left sealed and the other one I ported. (which is the one I use) The ported was better and put out much more bass. Of course I have 200 watts going to each little 8. Great bass for such a small enclosure.
Old Mar 19, 2007 | 02:37 PM
051fdrof's Avatar
Dupuis,
My math makes your sealed box 0.69 cubic feet using 3/4" MDF. That's going to work out perfectly for my Polk MM2084. They need 0.35 each in a sealed box.
Maybe your RE8s needed more volume in a sealed box?
Old Mar 19, 2007 | 04:07 PM
Dupuis's Avatar
Originally Posted by 051fdrof
Dupuis,
Nice looking subs!
I used 5/8'' MDF and put bracing for to prevent flexing. Your right, I made the biggest box I could for that area and it was still to small for both sealed and vented. But, to my surprise, these RE8s really stand out in this smaller vented box. Not so in the smaller sealed box.
Old Mar 19, 2007 | 05:22 PM
bird4352's Avatar
Just finished mine
https://www.f150online.com/galleries....cfm?num=13414
https://www.f150online.com/galleries....cfm?num=13413
