SI Mag / Box
Old Feb 4, 2007 | 04:11 AM
BigDave4's Avatar
SI Mag / Box
Can you guys provide some info/links to pics of your setup of these? What box are you using? How did you lift the seats?
I need to do something about the sub soon and I may go in this direction.
Dconder,
I know you are running a 12 and I have been looking for a link to your gallery, but can't find one.
Thanks in advance.
Dave
Old Feb 4, 2007 | 08:40 AM
dconder's Avatar
Dconder,
Thanks in advance.
Dave
Click the little camera in the upper right corner of my posts. It should take you to my gallery.
I do have a single 12" Mag under the seat with a seat lift kit from www.lmiwelding.com. My box is just like one of those premade wedge shape boxes. It sits on the left seat lift bracket and the middle hump. That's what raises it up off the floor. I will try and get some really good pics as soon as I get some carpet to cover it.
Old Feb 4, 2007 | 10:04 AM
Impact9's Avatar
How's that sounding compared to that 10 you replaced? This is killing me watching my pair sitting here collecting dust.
Old Feb 4, 2007 | 01:36 PM
dconder's Avatar
No comparison. The Mag just hits those lows with so much more impact.
Old Feb 5, 2007 | 12:09 AM
BigDave4's Avatar
dconder,
If I don't want to do the seat lift thing, what would you recommend? I would like something that can handle some more power. The JL 10w3v3 is being DOMINATED by my Rainbows so I need something with more depth in the sub.
I was looking at Brypink's gallery at the three setups he has had and as nice as they are, they all look like they require the seat lift.
TIA,
Dave
Old Feb 5, 2007 | 09:12 AM
dconder's Avatar
dconder,
TIA,
Dave
You will not be able to get much better than the 10W3 without a lift. I had the IDQ's under mine before a lift. They sound great but, just not that big 12" impact. I think the only one Brypink had that was not a seat lift was the Treo's and I am not sure on it. The 10w7 and the Mag's use a seat lift. My only other idea without a lift is a pair of IDQ 12" subs. They have a mounting depth of 5 3/4". While I have not tried it, I think a person could get them to fit without a seat lift.
Old Feb 5, 2007 | 01:11 PM
brypink2's Avatar
If you want any sub worth wild your gonna need a seat lift. My Treos had a lift too, just the box wasn't as big as the one I have now. Although, I think they might fit w/o one...just have to compromise on box volume.
Old Feb 5, 2007 | 03:51 PM
BigDave4's Avatar
Thanks as usual gents. I may wait until the end of the year and try to switch to a pair of something like this...
Supposed Specs:
12TW5-4
Nominal Diameter: 12 in. (300 mm)
Continuous Power Handling: 300 W
One-Way Linear Excursion (Xmax): 0.38 in. (9.7 mm)
Voice Coil Diameter: 5.50 in. (140 mm)
Nominal Impedance: Single 4 ohm
Mounting Depth: 2.50 in. (63.5 mm)
Recommended Sealed Enclosure: 0.63 cu.ft. (17.7 liters)
Would really like something that will handle more power, but I realize that can't have it all.
Old Feb 5, 2007 | 03:53 PM
brypink2's Avatar
Supposed Specs:
12TW5-4
That's a viable option...I'm curious as how they will sound.
