Experiance with QLogic or MTX Sub Enclosures?
Old Jan 3, 2007 | 09:42 PM
TFord's Avatar
Does anyone have experience with the QLogic or MTX sub enclosures for the '04+ Screw?
Old Jan 3, 2007 | 11:44 PM
ieee_raider's Avatar
Got it in my '04 Scab ... see gallery for pics. Fits like a glove, just be careful on getting a sub that fits depth-wise.
Old Jan 4, 2007 | 09:12 AM
dconder's Avatar
I used the Q logic for a while. Not bad, fits good. Just a bit pricey for a box to hold a single 10. I paid less locally for a box to hold dual 10's.
Old Jan 5, 2007 | 03:37 PM
TFord's Avatar
Thanks, guys. Awesome pics of both trucks. So the QLogic enclusure is plenty rigid, huh?
Dconder, man that Alpine HU does look like it's part of the truck! How's your Sirius antenna work there under the windshield? I would imagine just fine since they're now making portable handheld units.
Old Jan 5, 2007 | 05:07 PM
dconder's Avatar
The Q logic should work good for you as long as you do not try to get too much out of it. There is a lot of plastic there.
The antenna works great. The only time I ever loose signal is when I pull in the garage or under Sonic Drive In or something like that. Driving down the road, I never loose it. The tuner is behind the radio so, it made for an easy run of cable.
Old Jan 7, 2007 | 02:37 PM
natedog04scab's Avatar
qlogic
I use qlogic enclosure had to add 1/2inch standoff ring around opening to fit JL W3 sub but it worked and sounds pretty good, the neighboors know when I pull up haha. looks clean as hell too very factory fit
Old Mar 10, 2007 | 10:29 PM
TFord's Avatar
Well, I ended up with the amplified MTX Thunderform. My dilema was finding a place to mount a sub amp, and this unit has it installed internally. It came pre-loaded with a T4500 woofer. I spent a couple of hours this afternoon "tuning" everything, and it REALLY sounds great along with my other components. Fits great and looks good, too.
Old Mar 11, 2007 | 07:39 PM
projektlift150's Avatar
hey deconder, that box with the 2 10's in it, does it fit under the seat or does it take up sum of the foot room. im looking to get one for my truck but when i went to a local shop he sayd he has to take up my leg room jus so i can get a decent sound out of it, i have a scab but theres still about the same room as yours cuz my dad has the screw and i measured. so i dont know wether to go to a diff shop and see if they can make what im looking for or if theres sumtin online similar to yours i can buy. if you know of anything let me know. thanks
Old Mar 20, 2007 | 06:24 PM
Joe1549's Avatar
TFord,
Do you have any problems with the amp on the MTX Thunderform cutting out?
I've had mine installed for a couple weeks now, and all of a sudden its' cutting out on songs with loud bass. I am going to mess with the gains on my line output converter and see if thats the problem. It sucks since it was working perfectly without cutting out or anything no matter how loud I went.
Hope you don't have this problem.
Old Mar 20, 2007 | 06:35 PM
intruder's Avatar
I had a MTX thunderform in my '97. I loved it but, they are a little pricy for what you get.
Old Mar 23, 2007 | 01:12 PM
Flexpipe's Avatar
Here you might want to try one of these. Screw sub boxes
Old Apr 10, 2007 | 10:35 PM
TFord's Avatar
Originally Posted by Joe1549
TFord,
Joe, just saw your post. Once I got it going I've had no problems. One of the speakers wires was disconnected upon arrival. Also, the power harness had bad solder joints which broke loose - MTX cust svc said a known problem and quickly replaced harness for free. Maybe you should check both for a loose connection.
I've been pleased so far - this thing rocks! Good luck!
