What Guage Speaker Wire?
For your speakers, 16 should be fine for doors and 14 should be fine for your sub. What's more important is the insulation and shielding. That's what'll cut out interference and noise.
As far as wiring up the amp, see:
http://www.the12volt.com/wiring/recwirsz.asp
Originally Posted by TXhustla
Would there be a performance difference using 18 on subs??
The risk with using 18 AWG is overpowering it. If you're constantly driving your sub at high volumes, you could melt the insulation. It depends on the current level.
Usually 18 AWG will have less insulation, so you could pick up some noise.
Originally Posted by SSpiro
Can I use a shielded speaker cable? Where do I ground? At the amp?
When you say melt do you literally mean come off(plastic)? RMS on both subs are 250, if it matters my boost is flat an gain is barely adjusted.....
Originally Posted by B-Man
Since when did speaker wire insulation protect from noise ???
Noise enters the amplified system normally at a weak grounding point (headunit/amp/crossovers) or cheap RCA cables. Sometimes bad sparkplug wires will toss in a bunch of wizzes and whistles.
