In Search of Speakers to Compliment my Pioneer Z1 HU
cool. I think I'll hit up a few electronics stores this weekend and try and listen to the different speakers.
I definitely know I want components up front, coaxials in the back, and an amp.
I'd love to be able to just put the amp in the dash though. Is that possible? Then I could utilize the stock wiring to the speakers.
Duke
Duke
if you get a quality amp like the one i suggested off of ebay there is no way to get it there without some really nice custom fabbing. Choices are really behind the rear seat or under the rear bench portion (you could mount it to the floor or probably better under the seat)
why are you trying so hard to avoid running the additional wiring?
here's how my set up looks....I have a/d/s that are in a different league so to speak than the 346's...and no tweeter mounting hardware came with them...however if you got those or really any other set you should have mounts in the box that should work....... maybe at worst case scenario you'd have to open up the hole with some slight sanding by hand or with the dremel (worst case scenario)
if the set you go with has no mount it's easy....i just bought a sheet of foam..comes kinda like plywood...shaved it to the right size and attached it to the back of tweet with a dab silicone...and a dab of silicone to the back of the foam....which rested against the sheet metal in the door and kept the tweeter protruding out of the factory hole about 3 mm's or so....then for good measure used some silicone construction adhesive to seal her is.....(easy to cut and remove too) process should only take a very short amount of time....
http://s98.photobucket.com/albums/l2...gAnch=imgAnch1
you'll need a set of these for the front doors too....http://www.audiooutfitter.com/store/159806/82-5600.html
u can even see, the tweet in the right in the pic has a flushmount that looks as though it would work great in the factory ford cut out...http://www.adst.com/products/mobile/3series/346cs.asp
I installed the Z1 myself and it felt like a ton of work.
I know you're right and behind the back seat is the best option, but it's just more work that I'm trying to avoid.
Duke
unless your shoveling snow into the truck I think you'd be fine mounting it to the underside of the seat as opposed to the floor under the seat. granted I only have an super cab but I'm sure you'd have a couple inches of room in between the amp and the floor.
I don't see as how you can avoid running speaker wire.....not until they develop wireless technonlogy further
