:confused:Need help with Ohms!
Old Oct 25, 2006 | 12:06 AM
lblair04's Avatar
Red face :confused:Need help with Ohms!
Hi,
I want to get a single 10 or 12 sub, but Im not sure what the difference between a 4 ohm DVC and a 2 ohm DVC sub is. The last sub I had was a Comp and its a single voice coil.... Need some help please.
Old Oct 25, 2006 | 12:10 AM
brypink2's Avatar
Originally Posted by lblair04
Hi,
A single 4 ohm DVC you can wire to either 2 ohms or 8 ohms.
A single 2 ohm DVC you can wire to either 4 ohms or 1 ohm.
This changes when you add another sub.
Look here for help:
http://mobile.jlaudio.com/support_pages.php?page_id=161
dmitt30's Avatar
Hi,
I think Dan Wiggins from Adire Audio tells it best:
http://www.adireaudio.com/Files/Tech...oilDrivers.pdf
Old Oct 25, 2006 | 12:22 AM
brypink2's Avatar
Good read...but, it basically just boils down to more wiring configurations.
Old Oct 25, 2006 | 12:25 AM
dmitt30's Avatar
Agreed And also better "cone handling" or "braking" as Dan puts it. But it's been forever since I read that article, so I could be WAY off
Old Oct 25, 2006 | 12:29 AM
brypink2's Avatar
Thanks for bringing back up...it's been a while for me too. I almost forgot about it.
Old Oct 25, 2006 | 01:15 AM
lblair04's Avatar
Thanks for the help, but I still must be a complete idiot...to get the two variations of ohms per sub, you have to wire them in series, or parralel, right? How to do you do it to achieve these two ohms? Parralel equals what ohm, and series equals what ohm? Im sorry
Old Oct 25, 2006 | 04:20 PM
dmitt30's Avatar
Parallel divides the ohm load, and series multiplies it.. sorta...
Use the Ohms calculator at: http://www.the12volt.com/caraudio/boxcalcs.asp
Old Oct 25, 2006 | 05:01 PM
Ray21's Avatar
Yup...
To get final ohm load for DVC subwoofers:
Parallel = VC ohm / 2
Series = VC ohm x 2
RF wiring wizard works to:
http://www.rockfordfosgate.com/rftech/wiringwizard.asp
Old Oct 25, 2006 | 08:44 PM
lblair04's Avatar
Thanks for everyone's help! If I didnt have you guys, I would be even stupider!
Old Oct 26, 2006 | 06:29 AM
hawaiianblood44's Avatar
Originally Posted by Melovidov21
ooo i like that. im just learning about this ohm thing hell i didnt even know about it. i just thought it was all about watts and watts of power.
Blood,
