ATTN: SAtownTX (and anyone else) - Box dimensions
Originally Posted by brypink2
I still want to build a box/seat combo. I just need the rear bottom seat of a 04-06 SCrew though. Idon't want to mess mine up.
I might even try a ported box.
Yeah, I can see how you need the actual seat for Bry Jr. and others
People are barely ever in the back of my truck though.Im going for ported this time around too. 2 cubes at 28 Hz, hopefully it still has darn good SQ, if not Im going right back to sealed
Originally Posted by dconder
Bryan...I assume your Mag's share the same space? You do not have seperate changers for each?
Yeah they share the same space...with it's odd shape I didn't think seperate chambers would sound that good. Plus, it would have been to hard to get the same air space between the two.
I thought so too. I am thinking about getting another 12" Arc and was just curious on that. Do you have any idea how much internal volume you ended up with? The Arc's optimum is only .9 so I would only need in the 1.8 range. Thanks.
Originally Posted by John Scaro
Found it Bryan
Would you guys recommend 2 JL's 10w6v2 firing forward or down with this type of box?
Your gonna have a hell of a time getting them to fit down firing. Forward firing is probably the better route. Especially, since you can get a grille to protect them. I really didn't hear a difference between forward firing or down firing. One of my favorite set-ups in my last truck was forward firing (a 12W7).
I hope the sound good facing forward because thats the route I think I'm going.
EDIT: I could not tell the difference.
John,
Thanks for bringing this thread back up and a big thanks to Bryan for doing the write up. I'll be building a box soon and it's great info to have.
I'm trying to visualize your setup, John. If the front of the box is 11", won't it be difficult to do forward firing with that sub's overall diameter of 10.5"? And unless you're going ported won't that enclosure be too much volume for the 10W6v2?
Originally Posted by Im_SCrewed
John,
