Stereo Install Help/Advice
Old Aug 16, 2006 | 11:35 PM
Brian 5.4's Avatar
Arrow Stereo Install Help/Advice
I've got a pretty basic question here. I have two JL 10W0 woofers with an Alpine mono amp that I took out of a truck I had several years ago. I was using an aftermarket deck with this setup in the last truck and built my own box and it sounded nice, and wiring was straight-forward with the RCA jacks in the head unit. I would now like to put the woofers in my 02 supercrew, but would prefer to use the stock CD player and head unit. I know that I'll need a line out converter to supply power to the RCA jacks, but do not know how to hook one of these up-I've never seen one. Do I tap into some wires on the back of the stereo? Tap into the door speakers? Is the line converter a plug and play unit? Basically, I'm looking for some install info for dummies when using an amp, woofers, and the stock HU. Any help is much appreciated.
Old Aug 16, 2006 | 11:45 PM
chrisrud15's Avatar
From what I have personally done i can tell you that it's real basic. Usually you just need to tap into some speaker wire. I tapped into my rear speakers in my 01 but I have also just tapped into all 4 speakers right behind the HU. If you google this it will give you a much better instruction and probably show you some pics o f the installation process.
