WTF.. Alpine Components blown?
Are they doing it on one particular song? Or all music (songs)? Check all the above that have been mentioned first. Also, like mentioned...do you have the amp set properly with a DMM or by ear?
Also...did you change any xover points...meaning are you rolling them off at a lower hz? Check that too, maybe you accidently lowered your xover points for the mids.
Originally Posted by SSpiro
Well, still running off the factory deck. I haven't finished the amp install yet for the hi's...
Originally Posted by Lumadar
That's probably the problem right there. Any set of components worth a dang need some power to do their thing...deck power (especially a stock deck) isn't going to do the job.
With nice components is easier to hurt them by underpowering them than by over powering them. They can usually handle 75 to 150 watts per channel. Most Head Units, even the good ones only put out about 14 watts RMS. So when you crank it up, the components are getting very dirty and possibly damaging power, instead of clean pure power that they need.
Lumadar, I'm trying to find someone that has had the opportunity to compare the sound of a JL Stealth box to say 3 8's firing up. Trying to decide which way to go.
Any idea?
Looking for clean tight and fast, ability to hit 808's would be nice but not at the expense of SQ. I've heard people say that 3 8's firing up sound better than 2 10's firing down. But I have yet to talk to anyone that has had the chance to compare it to JL's awesome Stealth box.
Thanks in advance
Tim.
Any idea?
Thanks in advance
Tim.
Tbrown - thanks for the reply but don't hijack the thread. :o
Thanks for the replies guys. I plan on slapping in an eclipse deck shortly..I'll find out then if they are blown or not.
