Polk MMC650
#31
Originally Posted by shtrdave
F150Truck'in
I looked at mine until it got dark out this evening. Did you cut the door panel for the 6.5 to fit or trim the edge of the metal rim around the speaker?
Are they installed from the front or did you mount them and then reinstall the door panel over the top of them.
It is hard to tell from the pics.
dave
The tweeter doesn't look so bad, but the other one is a bit large.
dave
not use what you mean here.. ??
#32
Thanks for the replies, I will put them in tomorrow.
Sometimes the translation is lost by the time it gets to the fingers from the brain.
What i meant was the tweeter doesn't look bad to install, but the woofer seems a bit big to fit in the opening.
I picked up a couple of metra adapter plates.
#33
Originally Posted by F150Truck'in
Fedex was real late getting here today with my Polks, But I did get the MMC650 in the back doors... I tested them at low power, to late to crank them in my driveway... from what I can tell, Infinity "Can't Touch This".... LOL
MMC6500 tomorrow in front doors
I have the Polk DB5250 (5 1/4")and they are really loud on the tweeters. I didn't notice any adjustments mentioned in the manual for the crossover for my speakers. I know some crossovers will drop the level on the tweets.
I have some 6812cf 6x8 infinity's in the rear doors and they sound better on the mids but their bigger speakers match my amp.
#34
Originally Posted by Impact9
How do they sound on the higher freqs?
my MMC6500 are cut at -6db on crossovers.. I don't think the DB series can be cut on the crossovers... if you have a EQ in your HU, you can turn them down there......
#35
No kidding about them being bright. I've been adjusting the eq in the headunit and it's a chore to find a nice balance. Been thinking of trying to redirect/move the tweeters out of my face cause that mount location high in the door is just too close for these tweeters.
I placed a order for the MMC650 to try out from millionsbuy. Great price compared to crutchfield! Their rated RMS matches my amp so it should sound better and provide better mid-bass. Might take my DB's and install them into that area below the shifter or buy some q-logic kick panels. It's been a decade or so since I took car audio seriously. So this should provide a few good headaches.
#36
MMC650 Coaxial DO NOT HAVE tweeter control on crossovers, just so you know...
#37
did you order MMC650 Coaxial or MMC6500 Components??
At least the tweeters won't be up so high this time so I don't shrill every time some high freqs come out at high volume.
#38
#39
Oh I wouldn't want to run the 6812's alone. The work pretty good as mid range fillers. The Polks db's are so bright it's been hard to dial them in on the mid range . I went ahead and orderd the MMC6500 this time including the zero. I bet going to pure MOMO all around will sound fantastic. Now I just need to get another amp to give them 6500s the proper power.
#41
Originally Posted by ckoerner
Is there anyway to get these in the front doors of a 2000 with out cutting up the plastic grill on the door panel as in the previous pictures?
https://www.f150online.com/forums/sh...000+door+panel
#42
#44
Originally Posted by fyerfytr
Truckin -
Looks like the Momo's were made for it! I will be ordering the same set up for my '04 Screw. Anything to be aware of? Yours looks great.
Mark
Mark
just don't buy them from MillionBuy.com...
#45
I've had mine a few weeks and they are really sounding good now that they are broken in. I would perfer 2 sets of the 6500's since they have a higher power rating. The 6500's also sound better on the mid bass than the 650's.
Aside from the warranty issue Millionbuy is a cheap place to buy from. I'd buy there before I would on ebay unless you find a good seller with an unbeatable deal.
