Best box in single cab?
Old May 14, 2006 | 10:39 PM
TXhustla's Avatar
I have 2 Memphis 10s on a Coustic amp. Listen to mostly rap and am looking for something that will pound. Any suggestions?
Old May 15, 2006 | 12:22 AM
styxnpicks's Avatar
bigger subs, bigger box, bigger amp
Old May 15, 2006 | 01:24 AM
RageOfOrder's Avatar
Well......
For rap you will want a ported enclosure, and you'll probably want to build it yourself. The port gives it that bigger, full sound you want with rap music. Also lets you tune the box nice and low.
Check out my gallery if you like...
One of these subs in a ported box tuned to 35Hz
Pounds hard but I couldn't fit the second sub in there and still maintain full seat movement...
You might be able to if your subs are shallower than mine (6.4" mounting depth)
Old May 15, 2006 | 12:08 PM
TXhustla's Avatar
Yeah local store told me ported is the best way to go. But honestly will it sound that much of a difference than sealed? Dam your depth is 6.4, thats big for a 10 must really pound. Mines are just 5
Old May 15, 2006 | 12:10 PM
styxnpicks's Avatar
the difference is about 3 extra dbs. and a better lower extension before the freq response rolls off. the downside is a ported box is going to be twice the size of a sealed box
Old May 15, 2006 | 12:24 PM
TXhustla's Avatar
So...will that make that much of a difference than sealed because I want it to hit to the best ability. But with the same subs an amp
Old May 19, 2006 | 04:57 PM
TXhustla's Avatar
Old May 30, 2006 | 12:24 PM
o4f1fiddy's Avatar
if you use a sealed box just make sure that you are able to build it to the specs of the sub, a sealed box in my opinion is way better then a ported i have never use any ported boxes always sealed and they have always sounded better then any of my friends and i have a smaller box then them butit is built to the specs of the sub btw im runnin a jl audio 12w6v2 dvc
Old May 31, 2006 | 03:13 PM
TXhustla's Avatar
Will a ported sound that much of a difference than sealed I listen to rap....
