need help with enclosure air space..
i have two MTX 8000.. what i need to know is how much air space i should build a box for.. here is a link to teh spec. of the subs..
http://www.mtxaudio.com/caraudio/pro...ubs/T8124A.pdf
down towards the bottom of teh page are frequency response diagrams of different enclosures..
i figured id go with a sealed enclosure.. what air space would be best?
thanks
thanks
thanks
thanks
But...since that isn't considered a SQ sub...the 1.0 ft^3 should do you fine.
what if i went witha "provent" where teh MDF wraps around the sub?
http://musicmooseaudio.com/k212.html
like this, but not the square subs..
im just looking to hit hard and clean..
yea between 1- 1.5 cubit feet per sub. If you want tight hard bass, sealed is the best way to go.
Or you could try buying this box,
perfect sub box link
-Patrick
-Patrick
