06 screw speaker wire
Old Apr 19, 2006 | 11:08 PM
jbeaty's Avatar
I'm installing new speakers front doors and rear doors I was wandering if any body could tell me the color code for speaker wires(which are +/-). I tried a search with no luck, thanks in advance. jimmy.
Old Apr 21, 2006 | 04:36 AM
IROC it's Avatar
I found the color coding to be accurate and consistent on the speakers in an '06 Screw with an '00 Excursion believe it or not. The link is a .pdf file, you'll need Adobe Acrobat reader to view it...
The power wiring however is different...
Looks like:
Left front + = orange w/lt. green stripe
Left front - = Lt. Blue w/white
Left rear + = tan w/yellow
Left rear - = grey w/lt. blue
Right front + = white w/lt. green
right front - = dark green w/orange
Right rear + = brown w/pink
Right rear - = orange w/red
I've also heard that the side closest to the clip that release the factory wires from the speaker is the + terminal, but you may want to verify that...
Also, you can double check the colors by placing an aftermarket wiring harness behind the headunit and writing down the results...
Hope that helps! (btw- the link is from www.me-mag.com )
