System over haul!
Old Apr 10, 2006 | 11:14 PM
GA FOO 88's Avatar
System over haul!
So it seems my amp is dead, tommorow ill be hooking my avalanche up to my friends 1605d just to finally hear it. Anyways im looking at a US amps 2000d, ribbon tweets and dayton 8 refs (4 ohm) to start off with. Then a new deck and seperate amps to go active.
Anyone know of any other 1 ohm stable mono amps (800 + w) for around 200, or any good deals around?
Old Apr 11, 2006 | 10:49 PM
GA FOO 88's Avatar
Alrite scratch the daytons, i just ordered some AA mids and plan to cross them at 3k with the BG Neo 3 ribbons. Anyone have any input on an external active x-over, or should i just get an eclipse deck? The new eclipse lines look pretty sexy in person, and i haven't even the seen the high end ones yet.
Old Apr 11, 2006 | 11:16 PM
Bartak1's Avatar
If you can swing the price Id get a HU that is 3 way active and a nice nice amp and just run the amp all pass. Do all the cross over stuff on the deck.
Of it you cant get a HU that can do 3 way, if you have a good amp with a nice, and highly adjustable xovers you can just do all the cross over stuff on the amp.
Old Apr 12, 2006 | 10:33 AM
GA FOO 88's Avatar
I think im forced to get a new h/u due to the fact that the ribbons are so sensitive, I would have to tone down the power of the amp, and my 9825 won't due that. For 3-way your refferring to the sub too rite?
Old Apr 12, 2006 | 12:47 PM
brypink2's Avatar
That new 7000 Eclipse (forgot exact model #) is pretty slick. Even the 5000. Also, look in to an Alpine HU that has proceesor control and get the H701. I guarantee you won't be upset with that combo, I love mine!
Why did you choose to go with ribbons?
Old Apr 12, 2006 | 10:25 PM
GA FOO 88's Avatar
The ribbons are 10 mm deep, can mount in the a-pillar area with no back plate, only need 10 watts, are hella cheap, and play down to 2k hz. So i figured id give them a shot.
Old Apr 13, 2006 | 10:22 PM
GA FOO 88's Avatar
Alrite i hooked the hifonics amp up to my sub and still nothing, so I am in the though process that my h/u has bad outputs or whatnot.
So who selsl the new eclipse decks online, i know soinicelctronix has the cd8445 for 300 with all wiring harnesses.
Old Apr 14, 2006 | 05:14 PM
Bartak1's Avatar
Soundomain.com has new Eclipse decks.
