wire harness for factory sub
Old Feb 13, 2006 | 11:36 PM
nu-supercrew's Avatar
Everyone seems to be getting their harness for the Audiophile sub woofer (in those f150's that aren't pre-wired) from installers.com. I sent 'em an email and they say they are dealer only? OK where do I go from here? Anyone have a Ford part # for this harness?
Old Feb 14, 2006 | 05:38 AM
jmpancoast's Avatar
These numbers came from an old post. I order the plug for the sub hook-up in the back of the HU from www.fordparts.com and it worked fine. Please try to verify these numbers with your dealer before you order them.
3U2Z-14S411-DLA: Connector w/ leads that plugs into head unit
3U2Z-14S411-CAAA: Connector w/ leads that plugs into sub/amp
You will have to use these to make up your own harness. I have the wiring diagram if you need me to e-mail it to you.
Good luck!
Old Feb 14, 2006 | 06:53 AM
this should be a sticky
Good luck!
Thaks , AGAIN ! jmpancoast, I searched this topic last night untill my eyeballs fell out, and finally found the above mentioned part #'s. This subject should really be a STICKY!
Old Feb 14, 2006 | 07:14 AM
jmpancoast's Avatar
I installed a powered Bazooka sub tube and ran the power directly from the battery. As far as the speaker wiring, I used a good quality, non-shielded, wire and ran the wires on the side of the truck opposite the 8 ga. power wire. I am e-mailing you the wiring diagram for the factory set up. Hopefully it will answer your questions.
Old Feb 18, 2006 | 01:32 PM
rta108's Avatar
Would you mind e-mailing me that diagram as well? I am finding conflicting information about whcih wire does what on that 4 wire harness.
Thanks,
rta108 at yahoo dot com
Old Feb 19, 2006 | 10:00 AM
rta108's Avatar
Thanks a ton!
Old Dec 10, 2006 | 06:52 PM
05F150XLT's Avatar
I know its an old thread but hopefully I can get some more info...
Hello,
I've searched hi and low for this information and part numbers because i'm in the same boat, I want to make my own harness for adding an amp to my audiophile head unit.
I just wanted to confirm before I ordered, is the part
an 8 pin harness? If i get this connector can i hook this up to my amp using the low level inputs on my amp? Or do I need a line out converter? Anyone know which pins are the signal wires?
jmpancoast, could you send me the wiring diagrams if you still have them? Thanks!!!!
Old Sep 5, 2017 | 09:58 PM
apost01's Avatar
Good luck!
any idea what kind of connector i would need if i have an aftermarket head unit? just ordered a factory sub but don't have the wire harness under the backseat.
