Subs??
Old Dec 18, 2005 | 01:52 PM
93ReefBlueLX's Avatar
Subs??
I have a 02 f150 supercab and was thinking about putting a small system in it and i was just trying to get some ideas about boxes or other setups what do some of you guys have. I would really like to keep the backseats and dont want to have to lose alot of space in the cab. Thanks
Old Dec 18, 2005 | 07:29 PM
jmpancoast's Avatar
I have ordered a powered Bazooka powered amp to hook up to an Audiophile head unit. This is being done in an 05 regular cab. I will let you know how it works out later this week, if that is of any help to you.
Good luck.
Old Dec 20, 2005 | 01:43 PM
spr_F150's Avatar
You'll get a lot of different opinions, so here's mine. My first sub setup was two re8's in a ported box I built. I used 2x2x2x1/4 alum channel to make a seat lift. Covered the box with matching carpet and you couldn't tell by looking that anything wasn't stock. Sounded good for what it was.
Old Dec 22, 2005 | 02:29 PM
LUKE_DUKE's Avatar
I have a 2002 F150 Extended cab. I have a Q-Logic box under the back seat. I have one 10" sub, Rockford Fosgate driven by an Alpine MRD-M300 amp. I am about to upgrade the sub to an Image Dynamics so i can run it in 2 ohm load, but right now, it's plenty loud enough for me. I have the amp under the small seat behind the driver side. The box is finished the same color as my interior, it blends right in. Hope this helps
Old Dec 27, 2005 | 11:48 PM
02screwOSU's Avatar
I just bought a box from a local shop for 60 bucks, it goes under my rear seat on the driver's side, and holds 2 10in...it sound real good for how tiny it is, i also put some polyfill in the box to help with air space sense it's a sealed box. i didn't have to do any modifying, it just slides under the seat
