Removing door panels?
Old Sep 16, 2005 | 03:06 PM
motoracer81's Avatar
Any one have any hints on taking the front and rear door panels off of a 2003 f-15- extended cab?
I am puting new speakers in soon.
Thanks,
Dan
Old Sep 17, 2005 | 06:56 PM
Waymond's Avatar
The top trim (panel) on the front door will just pull off with force, pry a screwdriver under the trim to start. Once you take the top trim off youll see the two screws and bolt holding the door on. Unscrew,unbolt and lift. The door light will twist out.
For te back doors unscrew the two screws where you unlatch the windows and just pry off. The pull the bottem panel will pull off.
Old Sep 17, 2005 | 07:56 PM
Flareford150's Avatar
go to http://www.fordf150.net then go to the HOW TO section in the nav bar. And there is a tutorial on how to do it. You may need to sign up to get the whole article. I forget on that one
Old Sep 17, 2005 | 10:35 PM
Johngs's Avatar
I have a little "how-to" in my gallery as well
https://www.f150online.com/galleries...w.cfm?num=4610
