Need quick buying assistance...
Old Sep 6, 2005 | 08:17 PM
kars85's Avatar
Need a new 10" DVC 2 ohm sub. It will go in a 1.2 cu.ft. sealed box to be powered by a 300W RMS/ 900W peak amp.
I was looking a JL Audio, anyone have any recommendations? I'm not real familiar with their line of products, though. I think they're more tuned for smaller enclosures, but I'm not sure.
Thanks in advance fella's...
Karson
Old Sep 6, 2005 | 09:24 PM
Bartak1's Avatar
If you go JL, the W3V2D2 would be the best match.
Others-Incriminator Audio 187 series, Adire Shiva, Sound Splinter Rl-i (only comes in dual 4, but I think if you email Mike he can get you a dual 2), Image Dynamics IDQ10D2 V.2---Those are a few I would look at.
www.incriminatoraudio.com
www.adireaudio.com
www.soundsplinter.com
www.imagedynamicsusa.com
www.jlaudio.com
Old Sep 6, 2005 | 09:26 PM
Bartak1's Avatar
Forgot Image Dynamics ID10D2 V.2 also
dconder's Avatar
I would recommend looking at the Image Dynamics IDMAX and Diamond Audio TDX. They will work in much smaller enclosures but, will work in one that big as well. Most subs will work in a bigger enclosure than recommended with no problems. The 300 watts is kinda low for the two subs I listed but, the IDMAX has very good sensitivity.
Old Sep 6, 2005 | 09:39 PM
Bartak1's Avatar
They are pretty nice to, your definatley gettin into some money with those though. Forgot about the Adire Koda now that I see Dconders sig, it takes 300-400 wrms(cant remember what the rating is off the top of my head), of course it cost a fair chunk of change too.
Old Sep 7, 2005 | 02:34 AM
kars85's Avatar
you da man Bartak (btw what's your name?...j/w)
what COLOR of line is the most ideal based on WinISD's graph?
thanks so much for all your help man...i really appreciate it
Old Sep 7, 2005 | 12:34 PM
kuijo's Avatar
Resonant Engineering
Old Sep 7, 2005 | 02:52 PM
kars85's Avatar
where can you buy those at...i've googled my ballz off and came up w/ nothin...
[EDIT]...where can you buy ANY of those at except from manufacturer direct!
Old Sep 7, 2005 | 03:48 PM
Bartak1's Avatar
I thought about adding RE, but they dont really have anything to offer in the 300wrms range. The lowest model(RE) is rated at 150 wrms, and the next model up (SE) is rated at 600wrms. IMO theyve always had a gap there that they need to fill.
Id go with the yellow or green line. Although neither are the best way to go, they are the best options Yellow probably being best.
RE's site is www.reaudio.com
For the IA's, youll have to check out visionaryaudio.com to buy them, the Adire and SS will have to be bought direct. For ID, I THINK you can buy them direct, but I know SoundDomain has them, not sure where else.
Diamond can be found in numerous places.
Old Sep 7, 2005 | 08:17 PM
kars85's Avatar
woulda liked the IDQ, but Mike said he can't get me a dual 2 ohm VC. I'm looking more for SQ than SPL....what one of those above has better SQ (is that determined by sensitivity?)?
Old Sep 7, 2005 | 10:56 PM
GA FOO 88's Avatar
IDQ comes in dual 2 check ebay or www.woofersetc.com, i think you were talking about the rl-i from SS. I would go with the koda if you can, adire has a good rep from the brahma and extremis lines, so i think the koda couldnt be too far of pace if not right on.
Old Sep 9, 2005 | 12:00 PM
kars85's Avatar
strike 2 on the IDQ's...sounddomain has them on factory backorder listed @ $159, and factory direct they sell for $200...little too much $$ in my opinion
so it's either incriminator audio, jl audio, or adire...
Old Sep 9, 2005 | 01:35 PM
dconder's Avatar
You might consider the Elemental Designs 11Kv.2. I have one in a musicmoose box with only about 150 watts to it and it sounds really good. For $115 shipped, they are hard to beat.
Old Sep 9, 2005 | 05:20 PM
kars85's Avatar
well that'd definately be another option other than what i listed above, but they're out of stock for ~2 weeks
elemental design's customer service guy said that was bearing on how custom's treated they're incoming components...
every friggin place i turn with credit card in hand, they're on factory backorder!! tha's STRIKE 3 in my hunt to buy a sub... issed:
