Audiobahn
All of the audiobahn subs I have heard, are basically prety much crap. I havent heard any cadence subs hooked up, but tell us what you want out of your subs, like SQ, SPL, SQL. This will help and also give us a budget, and your choices of amps, and we can direct you towards some pretty good subs.
I have an 98 Ford
F-150 ext cab. I listen to rap. I plan on putting the subs under the back
bench in this box . I spent
$200 for both the subs and was going to spend $200 on the amp. I want two
10's but ill take two 12's if they will fit and are reasonable priced. I'm
willing to spend around the same priced I stated above, but willing to spend
more if neccesary.
more if neccesary.
Sorry i meant, what do you want out of your subs: loudness, or quality? Would you rather it have more bump and sound ok, or would you rather it sound better with less bump?
SQ = sound quality
SPL = sound pressure level = loudness
SQL = both SQ and SPL
For SQ i would look at Image dynamics, or EDs 11kv2s
For SPL i would go with Kicker CVR 10s
SQ = sound quality
They are a SQ sub made by Elemental Designs, www.edesignaudio.com . They dont get as loud as some of the other subs, but are known to be a decent sub for the price. Also check out www.reaudio.com , in their RE RE line the 10s are $66 and the 12s are $76. Both subs are the entry level subs for those companys, but they still sound clean and can pound.
