anyone running dual 8" woofers??
Old Apr 27, 2005 | 01:22 PM
crudeau's Avatar
One of these days my truck will arrive. But I was kicking around the idea of building my own enclosure for the truck. It's an 05 Scab. At first I was thinking the 10" JL stealth box, then I was thinking maybe just a 10w3 and build my own box.
But now my new idea is to buy the Seat kit to raise it up. And build a custom box for 2 8w7's to go in or 2 8w3's. This way the speaker may be able to fire forward instead of into the floor or the bottom of the seat. And the 2 8's would give me more surface area then one 10". What's everyone thoughts on this? I personally am not very keen on the idea of having puny 8's but I'm thinking two 8's compared to one 10 could be a good idea
With the seat rise kit installed what is the total height of the seat? If it's at least 9" then the subs could be installed this way.
8"w7 does require .86 cubic feet each though. Plus the .06 for each sub, so .92 each. Could work.
so many options
Old Apr 27, 2005 | 01:27 PM
sacramentojoe's Avatar
No but I"m running dual 10" woofers.
http://www.mtx.com/caraudio/products...hunder4500.cfm
with the T4510-44
Old Apr 27, 2005 | 01:45 PM
ThumperMX113's Avatar
If you want a really bad *** set-up do this. Get a box from supercrewsound.com. 2 Kicker L7 8's and a Kicker 850.2.
Old Apr 27, 2005 | 04:38 PM
crudeau's Avatar
I am pretty partial to JL. It's the box I am having a hard time with.
I'm pretty sure I want to build my own, and I want to have a front firing box, not up or down. I'm thinking that when I get my truck I will order the seat lift kit. Once that is installed I will make a scrap box so I can figure out how much volume I can get for two seperate boxes, from there I will go with either the 8w7 or the 8w3. Hopefully the 8w7's since I will get more umphhh out of them. Probably drive them with a JL 500.1 amp (either speaker option).
I'm just curious as to how the 2 8's would compare to one 10 of the same family. w3 or w7, from my research the 2 8's would be louder, cleaner, and hit a hair harder. Any insight?
Old Apr 27, 2005 | 05:04 PM
crudeau's Avatar
and dayum myself for putting this in the wrong forum. Can a mod put this in the sub/speaker section...
Old Apr 27, 2005 | 10:51 PM
Jakazz's Avatar
Hell, I'm working on getting 2 12" W7 in my SCAB. Got the back seat removed and all the wires in now. Just need to get the box built! It should rock!
Old Apr 27, 2005 | 11:04 PM
asinatra's Avatar
w7's are crap compared to xxx's
xxx
Old Apr 28, 2005 | 09:40 AM
crudeau's Avatar
I definetally don't want to remove my back seat.
Old Apr 28, 2005 | 09:44 AM
mslc1's Avatar
2 10's in a box under scab rear box came from subbox.net..750 watt alpine class d (more like 400) but hits pretty hard, gets low too i was surprised!! only limit is depth of speaker...had to run some cheap blaupunkts out of crutchfield but still impressed !!
Old Apr 28, 2005 | 10:54 AM
crudeau's Avatar
do you guys have pics of your installs? I really don't want to have the sub fire up or down.
I would really like to know what in the hell is taking my truck so long to get here. Thing has been at the ramps in Newark since the 20th and that is only 45 minutes from here. Damn union workers at the ramps.
Old Apr 28, 2005 | 11:16 AM
KNow where to find the seat lift kit?
Old Apr 28, 2005 | 11:33 AM
mslc1's Avatar
firing down into carpet actually sonds better,get a deeper bass.will try and take some pics and post ( wish me luck)
Old Apr 28, 2005 | 11:38 AM
40/99/04trucks's Avatar
04 supercrew i'm fired down and i built my own boxes w/2-10"fosgates (it pounds hard) 2 seperate boxes thats nice because you can allways take one out if need be and no one from the outside knows any different.2 fosgate amps and a eq stock deck (i got tired of those damnnn thieves steeling my system because they saw my deck) now its in hide it all mode. oh yeh infinity perf mids/tweets ill take pic later and post. M.W.
Old Apr 28, 2005 | 11:47 AM
crudeau's Avatar
I am going to get the truck before I make my decision. I will definetally go ahead and buy the lift for the seat. From there figure out where to go. My two choices are dual 8w7's firing forward, or space deciding, dual 10w3's firing down.
Speaker model wise, I stay with JL, I know there is more options for less, but I get a pretty sweet discount on JL from my buddy, so I stay with JL. He would probably disown our friendship if he saw me running something else.
I'd like to see all of your pics, and from them come up with a plan for mine. I definetally want dual chambers, don't need dual enclosures. Once they are in, they aren't coming out.
Old Apr 28, 2005 | 05:37 PM
Jakazz's Avatar
xxx
Are you talking about the Soundstream 15's?
