Audiophile Tweeters
Audiophile Tweeters
Does anyone have specs or part numbers for the front door mounted tweeters that come with the Audiophile package on the 2004 & 2005 F150's? Have any of you with Audiophile systems opened up the door panels and looked at these? How are they wired? Are the door speaker wires split and run through a crossover to the tweeters? If there is anyone out there who has removed the factory tweeters as part of an upgrade, I would sure be happy to take them off your hands!
scott <at> spillers <dot> cc
It is very easy to take the door grills off and check out the speakers. Just start prying the grille from the bottom. The door speaker is about a 4" or 5" round speaker mounted on a 6 x 8 housing to fit in the speaker hole. Also on the housing is a crossover to the tweeter. The rear door speakers are standard fare ford 6 x 8's
