Subwoofer enclosure
Subwoofer enclosure
Looks like Im going to have to custom build a new sub enclosure. The one I have is depriving. It fits under the backseat of my 2001 F150 XLT.
The reason I say its depriving, is, of course, because of the limited airspace. There isnt exactly a plethera of space underneath the 60/40 bench seat.
My ordeal is, Im considering removing the " 40 " seat and putting an enclosure in its place.
Only Im not sure what type of wood to use. I want to go to Home Depot or Lowes, and be able to purchase the wood. I have all the tools, exterior material and sealant, I just dont know what kind of wood will be optimal.
Thanks.
Thanks.
hey Dizzead,
I've got a JL Audio Stealthbox for sale that should fit your truck. It's only a year old. I had it in my 2000 F-150 ext cab. It should fit your truck as well. I bought a new truck and unfortunately it won't fit.
Only asking $225. It's a great sounding sub. Single 10" sub.
Fits perfectly under the rear passenger seat.
Let me know if you're intrested.
tskidmore@fuse.net
tskidmore@fuse.net
Hey instead of removing the 40 split seat just buy a lift kit for your back seat. I got one on ebay for $45.00. Would suggest just making your own though. The one i bought was suppose to be for a 97 to a 99. Did not fit my truck. Had to redrill holes and rebend the center bracket to make it fit. Just use 4" channel iron. I now have enough room to put my Rockford Fosgate Punch HX2's under there.
I have a 2000 F 150 SC with existing Kicker sub box (worthless)I’m thinking of
1) Rising rear seat 3” so that I could get a none ported box with 2 JL Audio 10W3v2 with JL 500/1 amp under front passenger seat but im thinking about headroom My daughter sit back their or
2) Remove the seat and install 13” height none ported box with the two 10W3 and amps on top with fans to vent the amps then go to the upholstery guy and have him make me a matching cushion for the top of the box and still have to have working seatbelt to work do you guys think is worth the effort Thanks in advance for your help Tony
Can’t decide
Can’t decide
DaFordFreak - Do you have any pics or an exact description of your seat lift kit? I'm hoping to (finally!) finish messing with my own sub box installation this weekend and would like to know what others have done for the seat lift/seat belt extension.
