Kicker L5 Subs
If they are dvc, you might be able to stick one sub on a amp, plus one VC from the third sub on it, and do the same with the other sub if you get what im saying. Youll probably end up with some wierd ohm load. Unless you got a 4 ohm dvc one that you could parallel wire down to 2 ohm, then get a 2 ohm dvc one and series wire once vc to the other sub for 4 ohms total, if you are bridging the amps.
