Sub Box Airspace Question
So when the specifications of a sub say the min/max amount of cubic feet of airspace for a box, is that with or without the sub?
Also, when you guys decide to build a box, how do you do it? Conventional geometry or a computer program? I've tried programs Blaubox and WinISD and found them so incredibly difficult I'm left asking here...
Thanks guys, your help is really appreciated
Pretty sure its net volume, subtracting the volume the sub takes up inside the box.
For simple boxes, I use BoxyCAD... its an excel spreadsheet and makes it easy to build rectangular boxes.
http://www.audiodiycentral.com/resou...xyCad-v1-1.xls
up vs down firing, that's a good question, i've seen both setups but haven't really seen much debate or rationale on here. Most of the pre-fabbed ones are down firing, I think. Down firing would probably do a better job of muffling any stray mid-bass output that isn't rolled off by your crossover.
mine is down firing, i'm thinking about putting mastic (similar to Dynamat) under the area of the floor where the sub fires.
