Downward firing sub?
Old Jan 25, 2001 | 10:20 AM
Larry@'s Avatar
Question Downward firing sub?
I have heard people say that a downward firing sub sounds better. How much room do you need between the box and the floor? Is 1 1/4" enough? Or would I be better off firing it up with 2" clearance between the seat and the box? Any advice greatly appreciated!
Old Jan 26, 2001 | 12:50 AM
lariat4wd's Avatar
Post
www.BMGSite.com/boxes
and
www.BMGSite.com/truck/page5
I build these, they sound awesome.
They fire down.
--Lariat4WD--
2000 Ford F-150 Extended Cab Flareside 4x4 Lariat
5.4L;auto;3.55LS;Black/Silver;ORP;remote keyless;floor-shift 4wd;Class III;AM/FM/SingleCD
Mods so far:
Lund X-Terminator bug shield; Vent Shade Vent Visors; GTS headlight blackouts; Westin Black step bars; Pendaliner bedliner; Genuine Steel Products (Longtek Engineering) black Safari Grille Guard; GTS Tail Blazer II Slotted taillight covers; Clear corner lenses; under hitch backup lights; 2 KC Hilites Daylighter 6" 150W black round off-road lights; Cranked torsion bars to level truck; Removed lower factory striping; Replaced factory gold & maroon ORP decals with silver; 2 Polk Audio EX10 10" subs under rear seat; Sony XM754HX amp; Viper 300ESP alarm
Pending
Replacing factory gold/maroon Lariat decals & upper stripes with silver & black
Wish list:
More lights; Flowmaster 40 Series single to dual exhaust w/ 18" SS tips out back; Optima red top battery; Remote starter & Prox. sensor; In-dash TV/CD/DVD/AM/FM head unit; Build house w/ huge garage with a drain and a lift.
Please Visit My Web Site (Updated Daily) and Sign My Guest Book
Old Jan 26, 2001 | 08:05 PM
Larry@'s Avatar
Question
I have a '98 so your boxes wont work. Im going to raise my rear seat 2" and make a box that will fit. I have quite a shop so making it wont be hard but I just didnt know how much clearance I would need. Do you know how much space is between your box and the floor? Thanks!
Old Jan 26, 2001 | 08:59 PM
Sandman_A_C's Avatar
Post
Larry,
1 1/4" should be enough, but it really depends on the sub. See if you can find the specs on the sub, they should tell you a peak excursion or something that will tell you how far the sub will travel.
I personally put 2 12" subs under my backseat and I just built 1 giant box and put a divider in it to make it a 2 chamber box. I installed the subs towards the ends of the box and used the center hump to hold the box off the floor where the subs are. It sounds great!
1998 F150 S/C
4.6 V8
Flowmaster 40 muffler
Sony CDX-C7850 CD Player
2 12" DEI Competition subs
DEI 1100D amp
4 kicker Impulse 5x7
Legacy LA360 amp
Expy console
SOON TO COME!!
Sony XE-744 Equalizer
Old Jan 27, 2001 | 02:31 PM
Lightning Struck93's Avatar
Post
I have a downfiring sub in a custom center console in my Gen1 Lightning..I believe you lose quite a bit of volume..I had to really watch my depth because I was using a Infinity Perfect 12.1 with some like 1/2" of excurision..I have mine spaced up about 2" from the seat bracket/floor..It's loud and all but it seems the more you space it up the louder the bass will be..I found this out when I spaced it up on rags that it got much louder...Just some food for thought.
Curt
93 Lightning #4232
Old Jan 27, 2001 | 06:26 PM
Larry@'s Avatar
Question
Sandman
I have a question for you. I see that you also have a '98. How did you make the box? Did you raise the seat (if so how much)? I was going to do the same thing with the hump but with the brace in the middle you can only put one speaker in. Did you take the middle brace out? What is the top mounting depth of your 12"? Thanks for any help!
Old Jan 31, 2001 | 07:52 PM
GetsumJ's Avatar
Thumbs down
In order to use any downfire system in a Extended cab, you must raise the seat.
When I went shopping for a system, the biggest obstical to overcome was that I refused to raise the seat.
So, I had a custom "Up Fire" Box built and just took 1st place in regional 1000 watt class, and 2nd in "Best Boom" overall. And I still retain the back seat in the stock position.
Kenwood 4015 CD Head
Kicker EQ/Pre amp
Kenwood 300 Watt Amp (Bridged) w CO
Kicker 700 Watt amp (Bridged) W co (For Subs)
4 6" Kicker 610s
2 2.25" Pzo's
2 12" Kicker Impulse
2 Custom built "Deco" Kick Panels
Acheived a "Perfect" .08 CF under rear seat.
It can be done, but it ain't cheap.
Total price installed
$3960.33
But Im happy , and very impressed :-)
Old Feb 1, 2001 | 12:00 AM
Larry@'s Avatar
Post
GetSum
Im assuming you have a new F150? The pre 2000 ones had a really low seat and its just about impossible to fit anything under there much less 2 12"s I raised my seat 1.75" and its actually more comftorable now. Im going to start making a box for 2 10"s this weekend.
Old Feb 1, 2001 | 12:22 AM
Post
Larry,
Sorry, it took so long to get back.
1) How did you make the box?
I just used some MDF board and made on giant box and then put a divider right down the middle to separate the two subs. I believe the volume of each side of the box was .8 cu/ft. I don't remember the exact dimensions for the box off the top of my head, but it was something like... 53"w x 6.5"t x 13"d. It ended up that I could have gone 50"w instead, and that would have been better because I am having problems installing my seat due to the fact that the box was almost too wide to fit the seat over.
2) Did you raise the seat (if so how much)? Did you take the middle brace out?
Yes, I did take the middle brace out. I have been riding around the past few months without a back seat(and I'm tired of that now), so I went today to a local company who is going to build me a custom lift for my truck. They measured a 3.5" lift necessary to mount my back seat. I know that that sounds like alot of lift, and it is. But I rarely have people riding in the back of my truck and from what I have read elsewhere on this board alot of people find the rear seat more comfortable when it is lifted. If you do lift your seat, try to find someone local. The only lift kits I have found online run you about $100. I am having the 2 side brackets and 2 seatbelt brackets built for $20 + tax.
3) What is the top mounting depth of your 12's?
6".
I should get my brackets for my seat around Friday, or maybe Monday. I will let you know if I have any problems.
GetsumJ,
Welcome to the board!
That is a pretty impressive system that you have there. You have the one thing that I lack, a component set. I plan on getting that in the next few months(when i get a little more $$).
I'm interested in your subs. You say that you mounted them firing up. Are they freeair subs or did you build 2 seperate boxes? Also, how much space is between the bottom of the seat and the subs? One of the reasons I went with the down firing subs is because there are tons of little screws sticking through the bottom of the rear seats in these trucks.
If you have any pics I would love to see them. You also say that you were in a local competition. What did your system meter at? I haven't metered mine yet, but it hits pretty hard.
And one last question, where did you mount your amps. I have a feeling you mounted one under each seat, that is the way I did mine.
1998 F150 S/C
4.6 V8
DEI 1100D amp
Legacy LA360 amp
Expy console
SOON TO COME!!
[This message has been edited by Sandman_A_C (edited 02-01-2001).]
Old Feb 2, 2001 | 12:26 AM
truckluver's Avatar
Post
Go here. They aren't down-firing, but they sound good. I would recommend the larger box. www.awpd.net
Thomas
1999 super cab
white with tan bottom
automatic
4.6L v8
WAAG grillguard
2 KC daylighters
vampire remote start combo alarm
steelhorse nerf bars
Husky chrome toolbox
2 10" Cerwin Vega subs
pyramid 800w amp
4 pioneer 3 way 6x8's
wants: 2 chamber flowmaster dual exhaust
tan fender flares
american racing atlas
2" fabtech suspension leveling kit
Old Feb 6, 2001 | 12:35 AM
GetsumJ's Avatar
Post
Larry,
Its built in one single box that extends accross under the seat. The 700watt Kicker is mounted between right on top of the "Hump". It all fits, though the box sticks out in front of the seat about 3/4 of an inch or so. It also slides out for easy access. Again, I cannot take credit for the installation. They guy that did it "Shades" had it all blueprinted on paper and installed to exact specs. He actually talked over my head quite a bit. I just went in and said, "I wanna win Comps" with it.
When they gauged my system, it registered a " 31 " , but I have no idea what that means. It was enough to win. :-)
My truck is posted in the members trucks page. Amazingly, I accomplished that. LOL
Thanks for comments. I am a Proud Truck owner, and I also have a 2001 Drop Top GT, no tunes, keepin it all original. But, working for Ford, the "A" plan is great.
Old Feb 14, 2001 | 01:55 PM
shy_texan's Avatar
Banned
Post
I have found a great box for 10" under the seat.
andy@frascone.com
<font face="Verdana, Arial" size="2">Originally posted by Larry@:
GetSum
</font>
