"Aiming" door speakers.
I upgraded the front speakers in my '05. They sound pretty good if I lean my head forward and down. Obviously the speakers aren't aimed optimally.
What is the best way to "aim" speakers?
The only way I can think of would be to use rubber grommets/washers between the doorpanel and the speaker at the attachment points.
A truck environment is a terrible place to tune an audio system because of hard surfaces, angled surfaces, etc. The only way is by trial and error. People sometimes spend hours setting up a single side of a component set. And, the user's preference is going to be different in every case. There is no perfect, generic way to do it. But, aiming frequencies above 2000hz at the listener is a place to start.
My Infinity Reference 5x7's have tweeters that can rotate 360 degrees so you can point them where you want them. You might consider those. I got mine from Crutchfield. And they come with a easy installation wiring harness that connects to your existing OEM speaker wire straight to the speaker.
Originally posted by Corpsie
I'm just talking about physically moving the speaker so it's "pointing" in a different direction than the stock position.
